Hi piholers,
I'll start off by saying I am running pihole in Docker, but I'm 50/50 on whether this question resides in the Docker install scripts or the core pihole install.
My goal is to include pihole's queries in Docker logging. By default, Docker doesn't capture pihole's query logs at /var/log/pihole.log
Sending pihole's queries to stderr
should put them in Docker's reach. So, I have attempted to customize dnsmasq by creating an additional file /etc/dnsmasq.d/logging.conf
log-queries=extra
log-facility=-
However, this doesn't work as these two options are already present in the default /etc/dnsmasq.d/01-pihole.conf
, so dnsmasq errors upon seeing the same options used twice.
Next, I attempted to set /etc/pihole/setupVars.conf
with QUERY_LOGGING=false
. It seems like basic-install.sh
would comment out the log-facility
line in 01-pihole.conf
with this setting, allowing me to use it in my own file. ([pi-hole/basic-install.sh at e41c4b5bb691cea1f5b950d39518d8c404b5846e · pi-hole/pi-hole · GitHub]) However, this doesn't work either, as log-facility
is not commented out after installation has completed.
My docker run
maps these directories:
--volume=/docker-volumes/pihole/etc/pihole:/etc/pihole/
, which includes my setupVars.conf
--volume=/docker-volumes/pihole/etc/dnsmasq.d:/etc/dnsmasq.d/
, which includes my
logging.conf
mentioned above.
So, is it possible to change the log-facility
setting, preferably as part of the automated install process?
Thanks for reading!
