Hey Everyone,
I've been using Pi Hole for quite some time
Has anyone had a crack at getting PI Hole to support PTR records/reverse DNS records via a package plugin etc?
Hey Everyone,
For DNS records managed by Pi-hole, Pi-hole would commonly create PTR records automatically.
What issue are you trying to address with the help of PTR records?
Hey thanks for the reply.
The issue I'm having is I can't create PTR records for internal IPs within my network.
Where/how did you configure names for your local devices?
Could you provide an example?
Typically you would map local client names to IP's in the Local DNS records section of the web admin GUI.
These are mapped in file /etc/pihole/custom.list.
