[Project] FilterHelm - Tool to help manage multiple Pi-Hole instances
I run multiple Pi-hole instances on my network for redundancy. I was having issues with configuration drift between the instances; either missed configuration, or inconsistencies between the instances. This helps to identify that drift in one spot.
FilterHelm can compare blocklists, local DNS entries, and basic settings across multiple Pi-hole instances, helping identify the differences and providing a way to resolve them.
It also supports managing those configurations directly. Changes are intentionally limited to one Pi-hole instance at a time to ensure instance changes are isolated, preventing Gravity updates impact the whole Pi-Hole fleet
There is also some basic functionality for query inspection and backup and status monitoring.
The repo includes instructions for running via compose, or directly.
AI Involvement
I’ve used AI-assisted development tools throughout the project, with a human-in-the-loop approach to implementation and decision making. I defined the high level feature requirements, leveraged Claude to iterate over the design, and Codex to provide the programming.
