Problem with pi-hole on server in Paris
Problem with my server = pi hole
Hello all, I install pi hole on my server in Paris, I dont know why website dosent work after install pi hole, system is Ubuntu 20.04 LTS (The Focal Fossa), 64 bits
log:
User info dashboard (pi-hole.net)
Best regards Adam
You have another process running on port 53 (named) and this is preventing pihole-FTL from binding to that port.
The solution is to stop and disable named, and restart pihole-FTL.
    udp:0.0.0.0:40906 is in use by avahi-daemon
[✗] udp:127.0.0.1:53 is in use by named (https://docs.pi-hole.net/main/prerequisites/#ports)
*** [ DIAGNOSING ]: Pi-hole diagnosis messages
   count   last timestamp       type                  message                                                       blob1                 blob2                 blob3                 blob4                 blob5
   1       2023-03-09 03:31:49  DNSMASQ_CONFIG        failed to create listening socket for port 53: Address alrea
                                                      dy in use
/Where name disabled? How to stop and restart pihole FTL ?
https://discourse.pi-hole.net/t/problem-after-updating-lost-connection-to-api/12487/6
sudo service pihole-FTL stop
sudo service pihole-FTL start
sudo service pihole-FTL restart
or
pihole restartdns
Thanks! Working fine :slight_smile:
Edit#
I got another problem with loading network.php amd logs etc I got error "An unknow error occured while loading the data" in logs I got as well
I add logs:
Your debug token is: https://tricorder.pi-hole.net/kXHBKXxv/
