instead of lighttpd
Regex filters taking priority over gravity blocks or let regex filters first, then gravity blocks the unfiltered regex.The issue is, sometime it can be a hurdle to check the regex filters ability to perform the task other than by other means.
-Raspiberry Pi
-Raspiberry Pi 4B]_
Gravity blocks take priority over regex filters.
[Replace this text with the debug token provided from running pihole -d
(or running the debug script through the web interface]
