PiHole Web interface should work, and allow traffic from my entire network to be filtered.
dnsmasq says unable to start, binding to port 53 failed due to port in use. I changed to port 5353, same issue, pihole-FTL service is using that port, but then I can't utilize the web interface due to this?! So confused....
In V4.0, dnsmasq is embedded in pihole-FTL, and dnsmasq no longer runs as a separate process. The debug log will show dnsmasq as either failed or inactive. Process pihole-FTL should be shown running on port 53. Your debug log shows:
Your debug log shows that lighttpd (the process that serves the web interface and block page) is running on port 80, which is correct.
The debug log also shows that Pi-Hole is blocking domains correctly:
[✓] www.pornland.mobi is 0.0.0.0 via localhost (127.0.0.1)
[✓] www.pornland.mobi is 0.0.0.0 via Pi-hole (192.168.0.130)
[✓] doubleclick.com is 172.217.4.142 via a remote, public DNS server (8.8.8.8)
The debug log also shows that there was some activity retrieved from the long term database when you last started Pi-Hole, indicating that Pi-Hole is blocking domains:
[2018-11-13 21:01:10.176] Imported 201 queries from the long-term database
[2018-11-13 21:01:10.176] -> Total DNS queries: 201
[2018-11-13 21:01:10.176] -> Cached DNS queries: 119
[2018-11-13 21:01:10.176] -> Forwarded DNS queries: 74
[2018-11-13 21:01:10.176] -> Exactly blocked DNS queries: 8
[2018-11-13 21:01:10.176] -> Unknown DNS queries: 0
[2018-11-13 21:01:10.176] -> Unique domains: 28
[2018-11-13 21:01:10.176] -> Unique clients: 5
[2018-11-13 21:01:10.176] -> Known forward destinations: 1
What URL are you using to access the web admin GUI and please post a screen capture(s) of what you are seeing.
I saw that in my logs for dnsmasq, but pihole-FTL utilizes port 53, as indicated by netstat -als.
Linked is the screenshot of what I see along with the web url: https://i.imgur.com/eKIOUCv.png
I tried changing the port pihole-FTL uses and every time it changes the dnsmasq port as well?
dnsmasq shouldn't be used, it is blocking ads on the server itself, not on the clients on the network (which the dns is set to the server). I still am unable to access the admin page to switch the listening interface to all within 1 hop.
Make sure that you still don't have this setting on the Pi-Hole host. Even though dnsmasq does not run as a separate process, pihole-FTL uses dnsmasq configuration files.
I reverted it back, I noticed it was still listening on port 5353. Just waiting to see some data to see if pihole is blocking on hosts 1 hop away or not.
Run a debug log and it will tell you if your Pi-Hole is resolving DNS queries properly. This section looks like this example:
[✓] www.ykbmvavx.org is 0.0.0.0 via localhost (127.0.0.1)
[✓] www.ykbmvavx.org is 0.0.0.0 via Pi-hole (192.168.0.155)
[✓] doubleclick.com is 216.58.192.206 via a remote, public DNS server (8.8.8.8)
If you choose, upload it and post the token and we'll look over it.
I restarted the server and updated DNS on my router, looks like that did the trick. I see everyone on the network and they're traffic. Thank you again @jfb you have been an amazing help!
