2021-06-07 09:18:47: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: SQLite3::query(): Unable to prepare statement: 11, database disk image is malformed in /var/www/html/admin/api_db.php on line 402
2021-06-07 09:18:55: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: SQLite3::query(): Unable to prepare statement: 11, database disk image is malformed in /var/www/html/admin/api_db.php on line 402
2021-06-07 09:18:57: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: SQLite3::query(): Unable to prepare statement: 11, database disk image is malformed in /var/www/html/admin/api_db.php on line 402
2021-06-07 09:19:01: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: SQLite3::query(): Unable to prepare statement: 11, database disk image is malformed in /var/www/html/admin/api_db.php on line
[2021-06-11 00:17:54.750 859M] getMACfromIP("192.168.178.169") - SQL error prepare: database disk image is malformed
[2021-06-11 00:17:54.750 859M] SQLite3 message: database corruption at line 68176 of [5d4c65779d] (11)
[2021-06-11 00:17:54.750 859M] SQLite3 message: database disk image is malformed in "SELECT name FROM network_addresses WHERE name IS NOT NULL AND ip = ?;" (11)
[2021-06-11 00:17:54.750 859M] getNameFromIP("192.168.178.169") - SQL error prepare: database disk image is malformed
[2021-06-11 00:17:54.751 859M] SQLite3 message: database corruption at line 68176 of [5d4c65779d] (11)
[2021-06-11 00:17:54.751 859M] SQLite3 message: database disk image is malformed in "SELECT interface FROM network JOIN network_addresses ON network_addresses.network_id = network.id WHERE network_addresses.ip = ? AND interface != 'N/A' AND interface IS NOT (11)
Deine pihole-FTL.db is kaputt.
Du kannst versuchen sie zu reparieren, oder verschiebst/löscht die kaputt einfach. Beim nächsten Start legt Pi-hole dann eine neue an.
