Pihole works on iphone when having secondary DNS but
#1
Ok so my pihole seems to be working fine on the PC when having a secondary DNS, but cant say the same for my iPhone. For example when I went to a few sites the ads still showed up I found online that you should only have the pihole as the primary DNS and delete the secondary as ads will still get through, but now webpages are stuck on a white screen loop then says safari could not open the page because the server stopped responding.
[Webpages should load]
[Webpage stuck on white loading screen on iphone]
[https://tricorder.pi-hole.net/pene1df0fi!]
#2
There should be no secondary DNS. All DNS traffic should go to Pi-Hole, with no other option available.
Your debug log shows that there is a mis-match between the IP assigned to the Pi and the IP to which Pi-Hole is assigned to listen. The assigned IP is 76 (on wireless), but Pi-Hole is listening on 75. Check your router for the IP of the Pi, note that IP and then reconfigure Pi-Hole for that interface and IP.
[✓] IPv4 address(es) bound to the wlan0 interface:
   192.168.0.76/24 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
   192.168.0.75/24 matches the IP found in /etc/pihole/setupVars.conf
#3
Thank you that fixed it!
closed #4
