Pihole working fine and accessing GUI ok
I got a ERR_CONNECTION_REFUSED in the browser. Trying to figure out with webservers and both (apache2 and lighttpd) are not working.
https://tricorder.pi-hole.net/m5p1f4j326
jfb
2
Apache and lighttpd will not be able to run at the same time on the same port. If they are both trying to start, one will fail.
Please repair pihole with pihole -r
and then upload a new debug log and post the new token.
I just removed apache2. here you have https://tricorder.pi-hole.net/8j4jg0wg8e
Thanks!
jfb
4
Did you repair the install?
jfb
7
Please send us a fresh debug token.
There are packages missing for lighttpd
. Try pihole -r
and reinstall.
Already did...nothing changed.
Try running the curl | bash
install again.
I had already done previously but didn't work..
Then I have no other suggestions.
system
Closed
18
