Raspberry Pi 5
I can't access pinhole after running the command:
sudo apt update && sudo apt upgrade -y
be aware I haven't updated this in about a year and Just ran it.
I have tried the following with http://. in front of it and without
10.10.10.200:8080
10.10.10.200:8080/admin/
10.10.10.200/admin/
10.10.10.200/admin/login.php/
10.10.10.200:8080/admin/login.php/
https://tricorder.pi-hole.net/5sgiMCjq/
issue resolved for some reason pie hole changed to Port 80 I had to reinstall a couple things thanks to Gemini
There are 2 different issues:
1. The web interface files are missing
Your debug log shows the files couldn't be found:
git status failed
Please try to repair the installation running sudo pihole -r.
If the repair attempt works, try to fix then next issue.
2. Two different web servers trying to use the same port:
Your debug log shows that you are running Pi-hole v6.4.2:
[✓] Version: v6.4.2
[✓] Version: v6.6.1
These URLs are not used by your Pi-hole.
Your log also shows lighttpd is using port 80. Pi-hole v6 doesn't use lighttpd or PHP. This was changed since Pi-hole v6.0.
Now, Pi-hole v6 uses its own web server.
The settings show Pi-hole is configured to use ports 80 and 443 (not port 8080), but lighttpd is already using port 80, so this port won't show Pi-hole web interface.
If you want to keep lighttpd on port 80, change Pi-hole ports using this command: sudo pihole-FTL --config webserver port '8080o,443os'. Then you will be able to access Pi-hole using any of these URLs:
If you don't use lighttpd for other services, you can safely uninstall it (sudo apt remove lighttpd) and them restart Pi-hole. Then you will be able to access Pi-hole using any of these URLs:
