Pihole should be blocking ads on clients as well as the host
clients just hang and domains do not resolve. Of note, this happened after I followed this tutorial to set up a VPN on my server: How To Set Up an OpenVPN Server on Ubuntu 18.04 | DigitalOcean
I have since completely uninstalled and reversed the tutorial, but the problem persists.
Additionally, I can completely reinstall pihole and it works perfectly, but after a reboot it, again, fails to resolve on clients. I can still ping sites from the server.
Thanks so much for any help. I searched the forums but I couldn't find anything that replicated my issue...
I get the error: [✗] There was an error uploading your debug log. When I try. Here is the output:
*** [ INITIALIZING ]
[i] 2020-01-18:13:47:21 debug log has been initialized.
[i] Core: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-ge41c4b5
[i] Web: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-g38d8e77
[✓] FTL: v4.3.1
[i] opt
[i] 7.2.24
[✓] Ubuntu 18.04.3 LTS
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[i] x86_64
[✓] IPv4 address(es) bound to the enp3s0 interface:
192.168.1.207/24 matches the IP found in /etc/pihole/setupVars.conf
[✓] IPv6 address(es) bound to the enp3s0 interface:
fe80::6a05:caff:fe2d:a904 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
* Pinging 192.168.1.1...
[✓] Gateway responded.
[i] Default IPv6 gateway: dev
* Pinging dev...
ping: dev: No address associated with hostname
*:8096 EmbyServer (IPv6)
*:8920 EmbyServer (IPv6)
*:25565 java (IPv6)
*:25566 java (IPv6)
*:22 sshd (IPv4)
*:22 sshd (IPv6)
*:445 smbd (IPv6)
*:139 smbd (IPv6)
*:445 smbd (IPv4)
*:139 smbd (IPv4)
[192.168.1.207:53] is in use by pihole-FTL
[127.0.0.1:53] is in use by pihole-FTL
[[fe80::6a05:caff:fe2d:a904]:53] is in use by pihole-FTL
[[::1]:53] is in use by pihole-FTL
[127.0.0.1:4711] is in use by pihole-FTL
[[::1]:4711] is in use by pihole-FTL
127.0.0.1:3306 mysqld (IPv4)
[*:80] is in use by lighttpd
*:443 apache2 (IPv6)
[10.2.144.1:53] is in use by pihole-FTL
[[fe80::e07d:bff:fe3f:dd7b]:53] is in use by pihole-FTL
[[fd42:cbfa:4f3e:9468::1]:53] is in use by pihole-FTL
[✓] clad.perfectcorp.com is 0.0.0.0 via localhost (127.0.0.1)
[✓] clad.perfectcorp.com is 0.0.0.0 via Pi-hole (192.168.1.207)
[✓] doubleclick.com is 216.58.192.174 via a remote, public DNS server (8.8.8.8)
[✓] regionalnyportal.eu is :: via localhost (::1)
[✓] regionalnyportal.eu is :: via Pi-hole (fd42:cbfa:4f3e:9468::1)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
[✗] lighttpd daemon is inactive
PIHOLE_INTERFACE=enp3s0
IPV4_ADDRESS=192.168.1.207/24
IPV6_ADDRESS=fd42:cbfa:4f3e:9468::1
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
INSTALL_WEB_SERVER=false
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=false
BLOCKING_ENABLED=true
HTTP/1.1 200 OK
Date: Sat, 18 Jan 2020 13:47:28 GMT
Server: Apache/2.4.29 (Ubuntu)
Last-Modified: Tue, 04 Dec 2018 15:49:03 GMT
ETag: "0-57c34347842a8"
Accept-Ranges: bytes
Content-Type: text/html
[✗] Web interface X-Header: X-Header does not match or could not be retrieved.
HTTP/1.1 200 OK
Set-Cookie: PHPSESSID=a2817h63iqbbi996h0um8qp9ue; path=/
Expires: Thu, 19 Nov 1981 08:52:00 GMT
Cache-Control: no-store, no-cache, must-revalidate
Pragma: no-cache
Vary: Accept-Encoding
Content-Type: text/html; charset=UTF-8
-rw-r--r-- 1 root root 2887777 Jan 18 13:41 /etc/pihole/gravity.list
0.0.0.0
0.nextyourcontent.com
0.r.msn.com
0.start.bz
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 313 Jan 18 01:11 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 104 Jan 18 13:41 /etc/pihole/local.list
192.168.1.207 server
fd42:cbfa:4f3e:9468::1 server
192.168.1.207 pi.hole
fd42:cbfa:4f3e:9468::1 pi.hole
-rw-r--r-- 1 root root 238 Jan 18 01:12 /etc/pihole/logrotate
/var/log/pihole.log {
su root syslog
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root syslog
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1389 Jan 18 01:12 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=8.8.8.8
server=8.8.4.4
interface=enp3s0
-rw-r--r-- 1 root root 1704 Jan 18 01:12 /etc/cron.d/pihole
11 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
39 15 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
/var/log/lighttpd does not exist.
ls: cannot access '/var/log/lighttpd': No such file or directory
-rw-r--r-- 1 pihole pihole 18476 Jan 18 13:41 /var/log/pihole-FTL.log
[2020-01-18 01:12:59.137 5722] Using log file /var/log/pihole-FTL.log
[2020-01-18 01:12:59.137 5722] ########## FTL started! ##########
[2020-01-18 01:12:59.137 5722] FTL branch: master
[2020-01-18 01:12:59.137 5722] FTL version: v4.3.1
[2020-01-18 01:12:59.137 5722] FTL commit: b60d63f
[2020-01-18 01:12:59.137 5722] FTL date: 2019-05-25 21:37:26 +0200
[2020-01-18 01:12:59.137 5722] FTL user: pihole
[2020-01-18 01:12:59.137 5722] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2020-01-18 01:12:59.137 5722] SOCKET_LISTENING: only local
[2020-01-18 01:12:59.137 5722] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2020-01-18 01:12:59.137 5722] MAXDBDAYS: max age for stored queries is 365 days
[2020-01-18 01:12:59.137 5722] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-01-18 01:12:59.137 5722] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-01-18 01:12:59.137 5722] DBINTERVAL: saving to DB file every minute
[2020-01-18 01:12:59.137 5722] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-01-18 01:12:59.137 5722] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-01-18 01:12:59.137 5722] PRIVACYLEVEL: Set to 0
[2020-01-18 01:12:59.137 5722] IGNORE_LOCALHOST: Show queries from localhost
[2020-01-18 01:12:59.137 5722] BLOCKINGMODE: Null IPs for blocked domains
[2020-01-18 01:12:59.137 5722] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-01-18 01:12:59.137 5722] DBIMPORT: Importing history from database
[2020-01-18 01:12:59.137 5722] PIDFILE: Using /var/run/pihole-FTL.pid
[2020-01-18 01:12:59.137 5722] PORTFILE: Using /var/run/pihole-FTL.port
[2020-01-18 01:12:59.137 5722] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2020-01-18 01:12:59.137 5722] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2020-01-18 01:12:59.137 5722] BLACKLISTFILE: Using /etc/pihole/black.list
[2020-01-18 01:12:59.137 5722] GRAVITYFILE: Using /etc/pihole/gravity.list
[2020-01-18 01:12:59.137 5722] REGEXLISTFILE: Using /etc/pihole/regex.list
[2020-01-18 01:12:59.137 5722] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-01-18 01:12:59.137 5722] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2020-01-18 01:12:59.137 5722] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-01-18 01:12:59.137 5722] PARSE_ARP_CACHE: Active
[2020-01-18 01:12:59.137 5722] Finished config file parsing
[2020-01-18 01:12:59.138 5722] SQLite3 message: cannot open file at line 38452 of [0eca3dd3d3] (14)
[2020-01-18 01:12:59.138 5722] SQLite3 message: os_unix.c:38452: (2) open(/etc/pihole/pihole-FTL.db) - (14)
[2020-01-18 13:34:40.568 1587] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-01-18 13:34:40.568 1587] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2020-01-18 13:34:40.568 1587] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-01-18 13:34:40.568 1587] PARSE_ARP_CACHE: Active
[2020-01-18 13:34:40.568 1587] Finished config file parsing
[2020-01-18 13:34:40.573 1587] Database version is 3
[2020-01-18 13:34:40.573 1587] Database successfully initialized
[2020-01-18 13:34:40.573 1587] New forward server: 8.8.4.4 (0/512)
[2020-01-18 13:34:40.574 1587] New forward server: 8.8.8.8 (1/512)
[2020-01-18 13:34:40.574 1587] Resizing "/FTL-strings" from 4096 to 8192
[2020-01-18 13:34:40.575 1587] Resizing "/FTL-strings" from 8192 to 12288
[2020-01-18 13:34:40.576 1587] Imported 1904 queries from the long-term database
[2020-01-18 13:34:40.576 1587] -> Total DNS queries: 1904
[2020-01-18 13:34:40.576 1587] -> Cached DNS queries: 303
[2020-01-18 13:34:40.576 1587] -> Forwarded DNS queries: 1464
[2020-01-18 13:34:40.576 1587] -> Exactly blocked DNS queries: 137
[2020-01-18 13:34:40.576 1587] -> Unknown DNS queries: 0
[2020-01-18 13:34:40.576 1587] -> Unique domains: 402
[2020-01-18 13:34:40.576 1587] -> Unique clients: 4
[2020-01-18 13:34:40.576 1587] -> Known forward destinations: 2
[2020-01-18 13:34:40.576 1587] Successfully accessed setupVars.conf
[2020-01-18 13:34:40.581 1623] PID of FTL process: 1623
[2020-01-18 13:34:40.581 1623] Listening on port 4711 for incoming IPv4 telnet connections
[2020-01-18 13:34:40.581 1623] Listening on port 4711 for incoming IPv6 telnet connections
[2020-01-18 13:34:40.581 1623] Listening on Unix socket
[2020-01-18 13:34:40.758 1623] Received SIGHUP, reloading cache
[2020-01-18 13:34:40.758 1623] Blocking status is enabled
[2020-01-18 13:34:40.758 1623] INFO: No whitelist file found
[2020-01-18 13:34:40.758 1623] Compiled 0 Regex filters and 0 whitelisted domains in 0.1 msec (0 errors)
[2020-01-18 13:34:41.953 1623] /etc/pihole/gravity.list: parsed 124212 domains (took 1045.1 ms)
[2020-01-18 13:41:12.020 1623] Received SIGHUP, reloading cache
[2020-01-18 13:41:12.020 1623] Blocking status is enabled
[2020-01-18 13:41:12.020 1623] INFO: No whitelist file found
[2020-01-18 13:41:12.020 1623] Compiled 0 Regex filters and 0 whitelisted domains in 0.0 msec (0 errors)
[2020-01-18 13:41:12.387 1623] /etc/pihole/gravity.list: parsed 124212 domains (took 281.1 ms)
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 331776 Jan 18 13:34 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 Jan 18 13:34 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 98304 Jan 18 13:34 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 20480 Jan 18 13:34 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 48 Jan 18 13:34 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 12288 Jan 18 13:34 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 229376 Jan 18 13:36 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 Jan 18 13:34 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 12288 Jan 18 13:34 /dev/shm/FTL-strings
*** [ DIAGNOSING ]: Locale
LANG=en_US.UTF-8
-rw-r--r-- 1 pihole pihole 689870 Jan 18 13:47 /var/log/pihole.log
-----head of pihole.log------
Jan 18 01:12:59 dnsmasq[5724]: started, version pi-hole-2.80 cachesize 10000
Jan 18 01:12:59 dnsmasq[5724]: compile time options: IPv6 GNU-getopt no-DBus no-i18n no-IDN DHCP DHCPv6 no-Lua TFTP no-conntrack ipset auth DNSSEC loop-detect inotify dumpfile
Jan 18 01:12:59 dnsmasq[5724]: using nameserver 8.8.4.4#53
Jan 18 01:12:59 dnsmasq[5724]: using nameserver 8.8.8.8#53
Jan 18 01:12:59 dnsmasq[5724]: read /etc/hosts - 9 addresses
Jan 18 01:12:59 dnsmasq[5724]: failed to load names from /etc/pihole/local.list: No such file or directory
Jan 18 01:12:59 dnsmasq[5724]: failed to load names from /etc/pihole/black.list: No such file or directory
Jan 18 01:12:59 dnsmasq[5724]: failed to load names from /etc/pihole/gravity.list: No such file or directory
Jan 18 01:12:59 dnsmasq[5724]: query[AAAA] raw.githubusercontent.com from 127.0.0.1
Jan 18 01:12:59 dnsmasq[5724]: forwarded raw.githubusercontent.com to 8.8.4.4
Jan 18 01:12:59 dnsmasq[5724]: forwarded raw.githubusercontent.com to 8.8.8.8
Jan 18 01:12:59 dnsmasq[5724]: reply raw.githubusercontent.com is <CNAME>
Jan 18 01:12:59 dnsmasq[5724]: reply github.map.fastly.net is NODATA-IPv6
Jan 18 01:12:59 dnsmasq[5724]: query[A] raw.githubusercontent.com from 127.0.0.1
Jan 18 01:12:59 dnsmasq[5724]: cached raw.githubusercontent.com is <CNAME>
Jan 18 01:12:59 dnsmasq[5724]: reply github.map.fastly.net is 151.101.0.133
Jan 18 01:12:59 dnsmasq[5724]: reply github.map.fastly.net is 151.101.64.133
Jan 18 01:12:59 dnsmasq[5724]: reply github.map.fastly.net is 151.101.128.133
