I use pihole -v
within a tasker task to check I'm up-to-date....started to see an error:
pi@pi-hole:~ $ pihole -v
Pi-hole version is v4.2.2 (Latest: ERROR)
AdminLTE version is v4.2 (Latest: ERROR)
FTL version is v4.2.3 (Latest: ERROR)
I use pihole -v
You are up to date, but Pi-Hole was unable to connect with the Github repository to get the latest version to compare to your local version.
From the Pi, run these commands and see if an IP is returned:
dig api.github.com
dig github.com
pi@pi-hole:~ $ dig api.github.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> api.github.com
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 23632
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 0, ADDITIONAL: 1
;api.github.com. IN A
api.github.com. 2866 IN A 192.30.253.116
api.github.com. 2866 IN A 192.30.253.117
;; Query time: 3 msec
;; WHEN: Sat Mar 16 19:10:12 GMT 2019
;; MSG SIZE rcvd: 75
pi@pi-hole:~ $ dig github.com
; <<>> DiG 9.10.3-P4-Raspbian <<>> github.com
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 34875
;; flags: qr rd ra; QUERY: 1, ANSWER: 2, AUTHORITY: 8, ADDITIONAL: 1
;github.com. IN A
github.com. 3600 IN A 192.30.253.113
github.com. 3600 IN A 192.30.253.112
;; AUTHORITY SECTION:
github.com. 2829 IN NS ns-1283.awsdns-32.org.
github.com. 2829 IN NS ns-1707.awsdns-21.co.uk.
github.com. 2829 IN NS ns-421.awsdns-52.com.
github.com. 2829 IN NS ns-520.awsdns-01.net.
github.com. 2829 IN NS ns1.p16.dynect.net.
github.com. 2829 IN NS ns2.p16.dynect.net.
github.com. 2829 IN NS ns3.p16.dynect.net.
github.com. 2829 IN NS ns4.p16.dynect.net.
;; Query time: 84 msec
;; WHEN: Sat Mar 16 19:10:49 GMT 2019
;; MSG SIZE rcvd: 291
Looks ok right?
Yes. Try pihole -v
again.
Yeah it works now?
I'm wondering if my tasker task kept trying to run the command, and hence repeated queries?
Would a lot of queries result in a short term 'ban' ?
I'll defer to the devs for this answer.
Github will rate limit you if you hammer the API with requests.
Why? Pi-Hole already checks for updates and highlights in the dashboard when an update is available.
That'll explain it! Thanks
Because why not?
I don't often open pihole GUI as it's setup to my liking and I have very few problems with it
