i setup pihole to use opendns only
pihole is using cloudflare and opendns
sudo grep 'New forward server' /var/log/pihole-FTL.log
[2019-09-21 09:57:32.563 17402] New forward server: 1.0.0.1 (0/512)
[2019-09-21 09:57:32.563 17402] New forward server: 208.67.220.220 (1/512)
[2019-09-21 09:57:32.564 17402] New forward server: 208.67.222.222 (2/512)
[2019-09-21 09:57:32.575 17402] New forward server: 1.1.1.1 (3/512)
what can i do to get rid of cloudflare and only use opendns?
https://tricorder.pi-hole.net/gpcy9udpxo
What is in your /etc/dhcpcd.conf?
interface eth0
static ip_address=192.168.2.66/24
static routers=192.168.2.1
and did you check the admin web page / Settings / DNS Servers?
jfb
3
Pi-Hole is using Open DNS now, and what you are seeing is due to how Pi-Hole acquires data from the long term database on startup.
Look in /var/log/pihole.log
for recent queries and see if any are going to Cloudflare now.
sudo grep forwarded /var/log/pihole.log | grep 1.*
system
Closed
4
