instead of lighttpd
[Ubuntu 16.15 server, upgrade to 5.0 FTL ]
[Ubuntu 16.15 server, upgrade to 5.0 FTL fails - can't connect to github]
[https://tricorder.pi-hole.net/4wtn9fgysg]
Running Pihole -d give a large output - however it seems to fail uploading and the local copy at /var/log/pihole_debug.log does not exist (even though it should).
Running pihole -up: at the end it lists ->
[i] FTL Checks...
[✓] Detected x86_64 architecture
[i] Downloading and Installing FTL...curl: (7) Failed to connect to github-production-release-asset-2e65be.s3.amazonaws.com port 443: Connection refused
Error: URL https://github.com/pi-hole/ftl/releases/latest/download/pihole-FTL-linux-x86_64 not found
[✗] FTL Engine not installed
