I am using:
Raspberry Pi OS Lite
standard Pi-hole
Raspberry Pi 2 hardware
$ uname -a
Linux pihole 5.10.103-v7+ #1529 SMP Tue Mar 8 12:21:37 GMT 2022 armv7l GNU/Linux
I saw that there was a new version of pi.hole software available, so I tried to upgrade using:
sudo apt update
sudo apt upgrade
pihole -up
The upgrade should have run through to completion.
The first "pihole -up" attempt failed with:
[i] Performing unattended setup, no dialogs will be displayed
/etc/.pihole/automated install/basic-install.sh: line 2616: getVal: command not found
Sometimes I have seen a glitch in a download and a second attempt recovers. The second "pihole -up" attempt failed with:
[✗] Retrieval of supported OS list failed. dig failed with return code 10.
Unable to determine if the detected OS (Raspbian 10) is supported
Possible causes for this include:
- Firewall blocking certain DNS lookups from Pi-hole device
- ns1.pi-hole.net being blocked (required to obtain TXT record from versions.pi-hole.net containing supported operating systems)
- Other internet connectivity issues
If you are seeing this message after having run pihole -up:
sudo PIHOLE_SKIP_OS_CHECK=true pihole -r
(In this case, your previous run of pihole -up will have already updated the local repository)
Finally the "sudo PIHOLE_SKIP_OS_CHECK=true pihole -r" attempt failed with:
[i] Repair option selected
At this point the pihole is working properly, but I do not want to attempt another install until the getVal issue is fixed.
