- Wireguard connection and DNS resolution through VPN
Local DNS resolution works without VPN, but when opening the before-functioning wireguard VPN I cannot reach any website or even resolve it. Also local adresses cannot be resolved.
The Wireguard server and clients were working without a problem before installation of the pi-hole and unbound reverse dns.
The vpn has a static ip with subdomain and wireguard port is forwarded to the pi as wireguard server.
PI has local 192.168.192.20 and routers DNS is set to this ip. Gateway is 192.168.192.1
The pihole has unbound reversedns as upstream dns service and conditional forwarding to the router. Listen on all interfaces and permit all origins is checked.
Funny thing is the wireguard vpn makes the connection and also sends data and if I do it with Notebook the client with ip 10.10.10.2 also appears with IP in the client section of pi-hole. But cannot open any site. with the phone it doesnt even appear and cannot open anything also.
Thanks for any advice.
[wg-server-conf]
[Interface]
Address = 10.10.10.1/24
ListenPort = 51820
PrivateKey = ******************************************
PostUp = iptables -A FORWARD -i %i -j ACCEPT; iptables -A FORWARD -o %i -j ACCEPT; iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
PostDown = iptables -D FORWARD -i %i -j ACCEPT; iptables -D FORWARD -o %i -j ACCEPT; iptables -t nat -D POSTROUTING -o eth0 -j MASQUERADE
Client1 PC
[Peer]
PublicKey = *****************************************
AllowedIPs = 10.10.10.2/32
Client2 smartphone
[Peer]
AllowedIPs = 10.10.10.3/32
[wg-client-conf]
[Interface]
Address = 10.10.10.3 / 10.10.10.2 (depending on client)
DNS = 192.168.192.20
[Peer]
Endpoint = SUB-DOMAIN:51820
AllowedIPs = 0.0.0.0/0, 192.168.192.0/24
PersistentKeepalive = 25
13v8p1sp6e
