Yes wlan0 was down, i used eth0 only while configuring to be sure that wlan is not affecting, but with sudo nmtui command i seen that my pi is still scanning wifi networks even when wlan0 is down soo better to fully disable it this way it will also use less power.
Only my home devices need to be connected via wifi, not pi hole soo its okey oh wait yeah its a mistake to disable then right ?
Well my devices connect to my router wifi which is connected to my pi via eth0 soo all should work fine i guess
