When you access
you are not allowed to click "new topic"?
When you access
ooh i clicked on implemented that why.
so how got the the pi hole web client up then i ran this
sudo systemctl status lighttpd
● lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled; vendor preset: enabled)
Active: active (running) since Sun 2020-07-12 22:16:06 UTC; 9min ago
Process: 1388 ExecStartPre=/usr/sbin/lighttpd -tt -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 1450 (lighttpd)
Tasks: 6 (limit: 9301)
Memory: 29.3M
CGroup: /system.slice/lighttpd.service
├─1450 /usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf
├─1462 /usr/bin/php-cgi
├─1524 /usr/bin/php-cgi
├─1525 /usr/bin/php-cgi
├─1526 /usr/bin/php-cgi
└─1527 /usr/bin/php-cgi
Jul 12 22:23:49 rick sudo[98042]: pam_unix(sudo:session): session closed for user root
Jul 12 22:24:00 rick sudo[100091]: www-data : TTY=unknown ; PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole enable
Jul 12 22:24:00 rick sudo[100091]: pam_unix(sudo:session): session opened for user root by morty(uid=0)
Jul 12 22:24:00 rick sudo[100091]: pam_unix(sudo:session): session closed for user root
Jul 12 22:24:01 rick sudo[100319]: www-data : TTY=unknown ; PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Jul 12 22:24:01 rick sudo[100319]: pam_unix(sudo:session): session opened for user root by morty(uid=0)
Jul 12 22:24:01 rick sudo[100319]: pam_unix(sudo:session): session closed for user root
Jul 12 22:25:23 rick sudo[119199]: www-data : TTY=unknown ; PWD=/var/www/html/admin ; USER=root ; COMMAND=/usr/local/bin/pihole status web
Jul 12 22:25:23 rick sudo[119199]: pam_unix(sudo:session): session opened for user root by morty(uid=0)
Jul 12 22:25:23 rick sudo[119199]: pam_unix(sudo:session): session closed for user root
active : active now, I'm not sure what I did I was snooping in the files.
To be honest i'm new to linux and I started googling about ssh and I change my ssh #22 to a random number. and I trying to use my phone to ssh in but couldn't gasp it or figure it out. Then I was trying to delete nextcloud but didn't know how and then I went to my ip and boom pi-hole shows up.
but the status on the pi hole: DNS service not running FTL offline
super weird i see a file in my downloads called pi-hole-teleporter_2020-07-12_10-02.42 and i dont recall downloading this file ??
I have Pi-hole running on Ubuntu 20.04 (Desktop version in a virtual machine). It is working 100% fine and went perfectly smooth using the usual one-line installer. I use the Pi-hole v5.0 version.
It is generated by Pi-hole when you use the Teleporter Backup feature on the Settings page or when you run some Pi-hole CLI command that does this.
Why did you do this? If your Pi-hole is not reachable from the Internet, you shouldn't do it. If it is, you shouldn't do it, either. Any port different from the default is bad. Two reasons: First, you may forget the exact number and it will cause headache for you. Second, a simple portscan can still find the random port immediately, it does not add a single bit of security (it just appears to do this, but it is an ill feeling of security which can quickly get you into trouble). One advice: SSH is a very very good and safe protocol. You you have it connected to the Internet, no big deal, however, instead of changing the port (which doesn't do anything), consider one of the following (or both):
There are excellent guides on the web for this.
Ok, so you got the web interface running?
So one issue fixed.
Please generate a new debug token.
Hello I will look into the certificates can sell phone have certs as well. and yes i will look up how to configure my firewall.
[✓] ** FINISHED DEBUGGING! **
* For more information, see: https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/
* If available, we'll use openssl to upload the log, otherwise it will fall back to netcat.
Yes, phones support this as well. I use the very popular SSH client JuiceSSH
. It works best among all apps I tried on Android. After over two years of using it, I even bought the premium for some advanced features (unrelated here) and this really means something for me. I refrain from giving any money to software, usually.
Thursday I will do a ubnutu desktop install on a flash drive and see if it's pi-hole installs and runs smooth on it vs unnutu server.
Please post the output of the log after you restarted pihole
pihole restartdns
cat /var/log/pihole-FTL.log
Add
Are you using the same Laptop to host pihole and to browse the internet? Or do you see ads using another device?
