*If you are Experiencing issues with a Pi-hole install that has non-standard elements (e.g you are using nginx
instead of lighttpd
, or there is some other aspect of your install that is customised) - I am using Pi-hole as recursive DNS server with unbound.
DNS resolutions to occur without timing out when accessing a new non-cached page. Joining a discord voice channel/streams without it taking long,
I notice timeouts at times when accessing google.com etc. Joining a discord voice channel or stream some times a bit longer for it connect (im guessing due to DNS timing out and retrying).
https://tricorder.pi-hole.net/0tpbpexK/
Please let me know what else i can offer as information. Im currently stuck and not sure what could be causing the issue.
