Hello.
Did anyone install the Pi-Hole on Android for instance ?
What about anyone having installed Pi-Hole on other types of SBCs:
Orange Pi, Khadas, etc. ?
Thanks.
Hello.
Thanks.
Android is not a Supported Operating System.
Running Pi-hole should be possible when there is a OS release available for it that is supported by Pi-hole.
For hardware with unsupported OSs, but which would be able to run Docker, you could consider to make use of Pi-hole's official Docker image.
