Pihole not updating
Updating pihole not working
When i try to update pihole using sudo pihole -up it says its uptodate.
But when i check te version with -v it shows its out of date.
This is probably an issue with your versions file.
Try sudo pihole updatechecker (nothing will be returned), then check the versions again with pihole -v.
This should fix it, but if after that the versions are still wrong, please generate a debug Token.
thank u this was it
