---= Daemon Process Information
::: Checking http port for lighttpd listener.
::: Failure: IPv4 Port not in use
::: ---= Daemon Process Information
::: Checking domain port for dnsmasq listener.
::: Checking 4711 port for pihole-FTL listener.
pi@raspberrypi:~ $ systemctl status dnsmasq.service
● dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: failed (Result: exit-code) since Tue 2017-10-24 23:53:53 CEST; 8h ago
Process: 648 ExecStartPre=/usr/sbin/dnsmasq --test (code=exited, status=1/FAIL URE)
pi@raspberrypi:~ $ ^C
pi@raspberrypi:~ $ pihole restartdns
Job for dnsmasq.service failed. See 'systemctl status dnsmasq.service' and 'jour nalctl -xn' for details.
pi@raspberrypi:~ $ journalctl -xn
No journal files were found.
pi@raspberrypi:~ $ pihole -d
::: Beginning Pi-hole debug at Wed 25 Oct 08:16:10 CEST 2017!
::: This process collects information from your Pi-hole, and optionally uploads
::: it to a unique and random directory on tricorder.pi-hole.net.
::: NOTE: All log files auto-delete after 48 hours and ONLY the Pi-hole developers
::: can access your data via the given token. We have taken these extra steps to
::: secure your data and will work to further reduce any personal information gathered.
::: Please read and note any issues, and follow any directions advised during this process.
::: ---= Detecting Installed Package Versions:
::: Pi-hole: v3.1.4 (master:v3.1.4-0-gb0ecedd)
::: Pi-hole Dashboard: v3.1 (master:v3.1-0-gf204b71)
::: lighttpd/1.4.35
::: PHP 5.6.30-0+deb8u1 (cli) (built: Apr 14 2017 16:20:58)
::: ---= Detecting existence of /etc/pihole/setupVars.conf:
::: File exists, parsing...done and was successfully sourced
::: ---= Detecting installed OS Distribution
::: ---= Checking processor variety
::: ---= Checking IPv6 Stack
::: IPv6 addresses located on eth0
::: No gateway detected.
::: ---= Checking IPv4 Stack
::: IPv4 addresses located on eth0
::: Pinging default IPv4 gateway: ::: Gateway responded.
::: Pinging Internet via IPv4: ::: Query responded.
::: Correctly configured.
::: ---= Processes Check
::: Logging status of lighttpd, dnsmasq and pihole-FTL...
::: ---= Resolver Functions Check (IPv4)
shuf: /etc/pihole/gravity.list: No such file or directory
Broadcast message from nut@raspberrypi (somewhere) (Wed Oct 25 08:16:43 2017):
UPS ups@localhost is unavailable
::: Checking for necessary lighttpd files.
::: ---= Detecting existence of /etc/lighttpd/lighttpd.conf:
::: ---= Detecting existence of /var/log/lighttpd/error.log:
::: ---= Detecting existence of /etc/dnsmasq.conf:
::: ---= Detecting contents of /etc/dnsmasq.d/*:
::: ---= File /etc/dnsmasq.d/01-pihole.conf found
::: Parsing...done
::: ---= File /etc/dnsmasq.d/02-pihole-dhcp.conf found
::: Parsing...done
::: ---= File /etc/dnsmasq.d/04-pihole-static-dhcp.conf found
::: Parsing...done
::: ---= File /etc/dnsmasq.d/README found
::: Parsing...done
::: ---= Detecting existence of /etc/pihole/whitelist.txt:
::: /etc/pihole/whitelist.txt not found!
::: ---= Detecting existence of /etc/pihole/blacklist.txt:
::: /etc/pihole/blacklist.txt not found!
::: ---= Detecting existence of /etc/pihole/adlists.list:
::: /etc/pihole/adlists.list not found!
::: ---= Analyzing gravity.list
grep: /etc/pihole/gravity.list: No such file or directory
::: Warning: No gravity.list file found!
::: ---= Analyzing pihole.log
::: Warning: No pihole.log file found!
::: ---= Analyzing pihole-FTL.log
::: Warning: No pihole-FTL.log file found!
::: --= User Action Required =--
::: Try loading a site that you are having trouble with now from a client web browser..
::: (Press CTRL+C to finish logging.)
::: ---= pihole.log
::: Logging will automatically teminate in 60 seconds
^C: 50 seconds left.
::: Finishing debug write from interrupt... Quitting!
::: Finshed debugging!
::: The debug log can be uploaded to tricorder.pi-hole.net for sharing with developers only.
::: Would you like to upload the log? [y/N]
::: Beginning Pi-hole debug at Wed 25 Oct 08:18:51 CEST 2017!
::: lighttpd/1.4.35
::: Parsing...done
::: Parsing...done
::: Parsing...done
::: Parsing...done
::: ---= pihole.log
::: Finshed debugging!.
::: Would you like to upload the log? [y/N] y
::: ---=== Your debug token is : lwk9b299b1 Please make a note of it. ===---
::: Contact the Pi-hole team with your token for assistance.
::: Thank you.
::: A local copy of the Debug log can be found at : /var/log/pihole_debug.log
pi@raspberrypi:~ $
That should restore the lists and cure the Warning: No gravity.list file found!
Be aware I am not a developer, have only been using Pi-Hole since the mid OCT.
You may of bought a ready image of Raspbian or did you do it yourself?
The journal problem could you summarize what PC you used and the program to do the Micro SD card if you burnt an image?
