The pi hole should be receiving queries form my desktop and blocking ads
No query is being resolved and windows says that the dns server is not responding, yet i can ssh into it and ping it. I can also ping outside the network from the pi and i can resolve from the pi
Your debug log shows this activity in the past 24 hours, so at least 3 clients have used Pi-Hole. One of the clients will be the Pi itself, so that leave two other clients.
[2019-10-13 21:30:26.823 13230] Imported 2871 queries from the long-term database
[2019-10-13 21:30:26.824 13230] -> Total DNS queries: 2871
[2019-10-13 21:30:26.824 13230] -> Cached DNS queries: 478
[2019-10-13 21:30:26.824 13230] -> Forwarded DNS queries: 1465
[2019-10-13 21:30:26.824 13230] -> Exactly blocked DNS queries: 838
[2019-10-13 21:30:26.825 13230] -> Unknown DNS queries: 90
[2019-10-13 21:30:26.825 13230] -> Unique domains: 432
[2019-10-13 21:30:26.825 13230] -> Unique clients: 3
[2019-10-13 21:30:26.825 13230] -> Known forward destinations: 6
From the Windows client command prompt, run these commands and post the output here:
nslookup pi.hole
ipconfig /all
From the Pi terminal, run this command and post the output here:
In the DNS settings on the PC, you have 8.8.8.8 also listed. When you have a non Pi-Hole DNS listed, some of the DNS traffic can go to that DNS server which will bypass Pi-Hole. To ensure all DNS traffic goes to Pi-Hole, eliminate the 8.8.8.8 DNS server.
The Pi-Hole is receiving queries from the PC (it has received 1625 of them in the past 24 hours).
How do you have your network configured where the Pi wlan IP is 10.104.243.221/22, and the gateway for that Pi is 10.104.240.2, but
the PC is on 172.16.96.93 with a gateway of 172.16.96.1 and a DHCP server of 10.101.4.43 and a DNS server of 10.104.243.221 (the IP of the Pi)?
I did have it set as the only dns server for my pc, but added googles when the issues started, so I could look for a solution online. The reason the network setup is so complicated, is that I live in a dorm at my universities campus. I cleared it with their networking department and they set a DHCP reservation for me at 10.104.243.221. When the issues started happening I couldn’t go to any websites, but I could ping them and go to them if I used the IP instead, after looking at the log, the pi didn’t show any more queries from my pc or my iPhone after about 7:43 pm
