pihole should update from raspiban and pihole servers, it should allow other devices to get ip lookups.
After a long run without any issues, suddenly things seem to have gone wrong......
Pihole cannot connect to raspbian or pihole servers. (ping servers from my laptop works OK)
No other devices can update when using pihole as dns server.
Gravity update fails.
pihole-d freezes at *** [ DIAGNOSING ]: Dashboard and block page ----- So no debug log available.
ip -4 route
default via 192.168.1.254 dev eth0 src 192.168.1.31 metric 202
192.168.1.0/24 dev eth0 proto kernel scope link src 192.168.1.31 metric 202
So the above looks OK to me....I am confused as to what has happened....This tells me to contact pihole support...
pihole -up
[i] Checking for updates...
fatal: unable to access 'https://github.com/pi-hole/pi-hole.git/': Could not resolve host: github.com
[i] Pi-hole Core: up to date
fatal: unable to access 'https://github.com/pi-hole/AdminLTE.git/': Could not resolve host: github.com
[i] Web Interface: up to date
[i] FTL: update available
[i] FTL out of date, it will be updated by the installer.
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Existing PHP installation detected : PHP version 7.0.33-0+deb9u3
[i] Performing unattended setup, no whiptail dialogs will be displayed
[✓] Disk space check
[✓] Checking apt-get for upgraded packages... 3 updates available
[i] It is recommended to update your OS after installing the Pi-hole!
[✓] Checking for apt-utils
[✓] Checking for dialog
[✓] Checking for debconf
[✓] Checking for dhcpcd5
[✓] Checking for git
[✓] Checking for iproute2
[✓] Checking for whiptail
[i] Performing reconfiguration, skipping download of local repos
[✓] Resetting repository within /etc/.pihole...
[✓] Resetting repository within /var/www/html/admin...
[i] Main Dependency checks...
[✓] Checking for cron
[✓] Checking for curl
[✓] Checking for dnsutils
[✓] Checking for iputils-ping
[✓] Checking for lsof
[✓] Checking for netcat
[✓] Checking for psmisc
[✓] Checking for sudo
[✓] Checking for unzip
[✓] Checking for wget
[✓] Checking for idn2
[✓] Checking for sqlite3
[✓] Checking for libcap2-bin
[✓] Checking for resolvconf
[✓] Checking for lighttpd
[✓] Checking for php7.0-common
[✓] Checking for php7.0-cgi
[✓] Checking for php7.0-sqlite3
[✓] Enabling lighttpd service to start on reboot...
[i] FTL Checks...
[✓] Detected ARM-hf architecture (armv6 or lower) Using ARM binary
Error: Unable to get latest release location from GitHub
[✗] FTL Engine not installed
