After looking on the forum I can not find an answer to my problem.
I installed Pihole in front of a squid proxy (installed on the same machine 192.168.57.2)
In my Squid config, I set the dns server to the pihole address (127.0.0.1, I modified the config dnsmasq to listen on the localhost).
On the client side, the dns server is 192.168.57.2, proxy = 192.168.57.2:3128
Everything works fine except that logically, in the query logs, I see only the ip "localhost" in the client column.
Will there be a way PiHole side to recover the XForwardedFor sent by Squid and know the original client?
Thanking you in advance for your help.
Regards
