Output from the repair
[β] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[β] Update local cache of available packages
[i] Existing PHP installation detected : PHP version 7.4.21
[β] Checking apt-get for upgraded packages... up to date!
[i] Checking for / installing Required dependencies for OS Check...
[β] Checking for grep
[β] Checking for dnsutils
[i] PIHOLE_SKIP_OS_CHECK env variable set to true - installer will continue
[i] Checking for / installing Required dependencies for this install script...
[β] Checking for git
[β] Checking for iproute2
[β] Checking for whiptail
[i] SELinux not detected
[i] Repair option selected
[i] Performing reconfiguration, skipping download of local repos
[β] Resetting repository within /etc/.pihole...
[β] Resetting repository within /var/www/html/admin...
[i] Checking for / installing Required dependencies for Pi-hole software...
[β] Checking for cron
[β] Checking for curl
[β] Checking for iputils-ping
[β] Checking for lsof
[β] Checking for netcat
[β] Checking for psmisc
[β] Checking for sudo
[β] Checking for unzip
[β] Checking for idn2
[β] Checking for sqlite3
[β] Checking for libcap2-bin
[β] Checking for dns-root-data
[β] Checking for lighttpd
[β] Checking for php7.4-common
[β] Checking for php7.4-cgi
[β] Checking for php7.4-sqlite3
[β] Checking for php7.4-xml
[β] Checking for php7.4-intl
[β] Checking for php7.4-json
[β] Enabling lighttpd service to start on reboot...
[β] Checking for user 'pihole'
[i] FTL Checks...
[β] Detected x86_64 processor
[β] Downloading and Installing FTL
[β] Installing scripts from /etc/.pihole
[β] Installed /etc/dnsmasq.d/01-pihole.conf
[β] Installed /etc/dnsmasq.d/06-rfc6761.conf
[i] Installing blocking page...
[β] Creating directory for blocking page, and copying files
[i] Backing up index.lighttpd.html
[β] Installing sudoer file
[β] Installing latest Cron script
[i] Installing latest logrotate script...
[i] Existing logrotate file found. No changes made.
[i] Backing up /etc/dnsmasq.conf to /etc/dnsmasq.conf.old
[β] man pages installed and database updated
[i] Testing if systemd-resolved is enabled
[i] Systemd-resolved does not need to be restarted
[β] Restarting lighttpd service...
[i] Restarting services...
[β] Enabling pihole-FTL service to start on reboot...
[β] Restarting pihole-FTL service...
[β] Deleting existing list cache
[β] Pulling blocklist source list into range
[β] Preparing new gravity database
[i] Using libz compression
[β] Status: Retrieval successful
[i] Analyzed 92995 domains
[i] Target: https://adguardteam.github.io/AdGuardSDNSFilter/Filters/filter.txt
[i] Analyzed 39602 domains, 39587 domains invalid!
Sample of invalid domains:
- 2021-09-14t18:04:54.201z
- ||videosprofitnetwork.com^
- ||phhitgjxsit.com^
- ||mujnmhmfhrubzq.com^
- ||wovazaix.com^
[β] Storing downloaded domains in new gravity database
[β] Building tree
[β] Swapping databases
[β] The old database remains available.
[i] Number of gravity domains: 372040 (93010 unique domains)
[i] Number of exact blacklisted domains: 0
[i] Number of regex blacklist filters: 0
[i] Number of exact whitelisted domains: 2
[i] Number of regex whitelist filters: 8
[β] Cleaning up stray matter
[β] DNS service is NOT listening
[i] The install log is located at: /etc/pihole/install.log
Update Complete!
Current Pi-hole version is v5.4
Current AdminLTE version is v5.6
Invalid Option! Try 'pihole -v --help' for more information.
