Pihole always offline after resizing *****
My debug token is: https://tricorder.pi-hole.net/a4wkqhodv7
You have a number of errors in your debug log
[i] Commit: v5.1.1-0-ga03d1bd-dirty
[i] Status: M .gitattributes
M .github/ISSUE_TEMPLATE.md
M .github/PULL_REQUEST_TEMPLATE.md
M .github/workflows/codeql.yml
M .github/workflows/test.yml
M .gitignore
[i] Diff: diff --git a/.gitattributes b/.gitattributes
old mode 100644
new mode 100755
diff --git a/.github/ISSUE_TEMPLATE.md b/.github/ISSUE_TEMPLATE.md
old mode 100644
new mode 100755
diff --git a/.github/PULL_REQUEST_TEMPLATE.md b/.github/PULL_REQUEST_TEMPLATE.md
old mode 100644
Did you modify the web branch/repository?
172.17.60.198/18 does not match the IP found in /etc/pihole/setupVars.conf
IPV4_ADDRESS=47.93.XXXX/24
This indicates you're running your pihole on a public IP address. Running open resolvers is not supported by pihole in any way.
80] is in use by apache2 (https://docs.pi-hole.net/main/prerequisites/#ports)
*:443 apache2 (IPv4)
[80] is in use by apache2 (https://docs.pi-hole.net/main/prerequisites/#ports)
You're running a webserver that is not supported.
Port 53 to other servers seems to be blocked (may be intentionally?).
/var/log/lighttpd does not exist.
[2020-09-23 00:57:24.517 2401M] -> Total DNS queries: 104170
[2020-09-23 00:57:24.517 2401M] -> Cached DNS queries: 28669
[2020-09-23 00:57:24.517 2401M] -> Forwarded DNS queries: 60518
[2020-09-23 00:57:24.517 2401M] -> Blocked DNS queries: 14979
[2020-09-23 00:57:24.517 2401M] -> Unknown DNS queries: 4
[2020-09-23 00:57:24.517 2401M] -> Unique domains: 6468
[2020-09-23 00:57:24.517 2401M] -> Unique clients: 108
[2020-09-23 00:57:24.517 2401M] -> Known forward destinations: 12
Your pihole is running.
The file contents haven't change but something/somebody made them executable. Which is a really wrong thing to do.
This is an open resolver. It's also very badly configured.
You'll get no help from the developers.
OK, I've known what's wrong with this issue.
