Pihole doesnt work
PiHole blocks blacklisted domains
PiHole is running and set up correctly (it worked fine before), but not blocking any ads
https://tricorder.pi-hole.net/5yh085ewpf
You Pi-hole seems to be working fine
   [2021-01-25 18:29:19.847 622M] Imported 9593 queries from the long-term database
   [2021-01-25 18:29:19.848 622M]  -> Total DNS queries: 9593
   [2021-01-25 18:29:19.848 622M]  -> Cached DNS queries: 3218
   [2021-01-25 18:29:19.848 622M]  -> Forwarded DNS queries: 4314
   [2021-01-25 18:29:19.848 622M]  -> Blocked DNS queries: 1946
   [2021-01-25 18:29:19.848 622M]  -> Unknown DNS queries: 62
   [2021-01-25 18:29:19.848 622M]  -> Unique domains: 964
   [2021-01-25 18:29:19.848 622M]  -> Unique clients: 15
   [2021-01-25 18:29:19.848 622M]  -> Known forward destinations: 4
Where do you see ads?
The only thing I noticed is that you use IPv6 in your network and globale IPv6 addresses are assigned to your Pi-hole device. There is a chance that other devices in your network use IPv6 to bypass pihole.
Okay, it just started working. Before that, it looked like it doesnt process my dns queries, I could access blocked domains and pi.hole web page didnt work
