Expected behavior:
Pihole in Wireguard and Openvpn.
I need server 2 to work the same as server 1.
Server 1, this works.
OS: Ubuntu 18.04.4 LTS x86_64
Host: VMware Virtual Platform None
Kernel: 4.15.0-99-generic
Shell: bash 4.4.20
CPU: Intel Xeon E7- 2850 (1) @ 1,997GHz
Memory: 345MiB / 962MiB
Server 2, this does not work.
Host: Hyper-V UEFI virtual machine version v1.0
Kernel: 4.15.0-101-generic
Shell: bash 4.4.20
CPU: Intel Xeon E5-2698 v3 (2) @ 2,299GHz
Memory: 216MiB / 1979MiB
I use www.pivpn.io to install Wireguard.
Current behavior:
Server 1 runs pihole on Openvpn and Wireguard.
Server 2 works pihole on Wireguard but not on Openvpn.
Server 1 Server.conf
topology subnet
server 10.8.0.0 255.255.255.0
verb 0
duplicate-cn
key client-key.pem
ca ca.pem
cert client-cert.pem
dh dh.pem
persistent key
persist-tun
comp-lzo
float
press "redirect-gateway def1 bypass-dhcp"
press "dhcp-option DNS 10.6.0.1"
#push "dhcp-option DNS 8.8.8.8"
#push "dhcp-option DNS 8.8.4.4"
user nobody
nogroup group
AES-128-CBC figure
proto tcp
port 4433
Dev Tun
status openvpn-status.log
customer to customer
client certificate not required
username as common name
plugin /usr/lib/openvpn/plugins/openvpn-plugin-auth-pam.so login
connect-retry 0 0
reneg-sec 0
tran window 0
hand window 120
keepalive 10 120
Server 2 Server.conf
topology subnet
verb 0
duplicate-cn
key client-key.pem
ca ca.pem
dh dh.pem
persistent key
persist-tun
comp-lzo
float
user nobody
nogroup group
AES-128-CBC figure
proto tcp
port 4433
Dev Tun
plugin /usr/lib/x86_64-linux-gnu/openvpn/plugins/openvpn-plugin-auth-pam.so login
connect-retry 0 0
reneg-sec 0
tran window 0
hand window 120
keepalive 10 120
Server 1 Pivpn Wireguard:
:::: Installation configuration ::::
PLAT = Ubuntu
OSCN = bionic
USING_UFW = 0
IPv4dev = ens160
install_user = user321
install_home = / home / user321
VPN = cable protection
pivpnPORT = 20276
pivpnDNS1 = 10.6.0.1
pivpnDNS2 =
pivpnHOST = REMOVED
INPUT_CHAIN_EDITED = 0
FORWARD_CHAIN_EDITED = 0
pivpnPROTO = udp
pivpnDEV = wg0
pivpnNET = 10.6.0.0
subnetClass = 24
UNATTUPG = 1
INSTALLED_PACKAGES = ()
:::: The server configuration is shown below ::::
[Interface]
PrivateKey = server_priv
Address = 10.6.0.1/24
ListenPort = 20276
Server 2 Pivpn Wireguard:
PLAT = Ubuntu
OSCN = bionic
USING_UFW = 1
IPv4dev = eth0
pivpnPORT = 20276
pivpnDNS2 =
pivpnHOST = REMOVED
pivpnPROTO = udp
pivpnDEV = wg0
pivpnNET = 10.6.0.0
subnetClass = 24
UNATTUPG = 1
[Interface]
ListenPort = 20276
Server 1: https://tricorder.pi-hole.net/tdvecvseqv
Server 2: https://tricorder.pi-hole.net/27dp099eh4
