PiHole Doesn't Start After upgrade to v6, pihole.toml missing
I also am facing the same problem. All settings seemed to have been wiped out. No upstream DNS servers were selected after upgrading. All local DNS records were erased. had to start using "sudo" in front of any pihole command in terminal. now can't use http, must use https (which was documented to be fair).
This is expected.
This is not true.
You can use http without issues. We just added the possibility to use https without needing a reverse proxy.
If you are not able to access via http, then open a new topic and provide a debug token.
Hmmm, ok. yea when I visited http:// after the upgrade I got a 403 forbidden.
Out of curiosity, any idea when that fix will be merged into master/main so I can switch back to a "normal" release? Thanks!
It has been released Pi-hole FTL v6.0.1 by PromoFaux · Pull Request #2222 · pi-hole/FTL · GitHub
