I'm trying to use pihole from docker on my mac. The container runs fine and I can access the webconsole without any problem.
The issue is that when I change my mac dns to try to use the pihole it does not work, domains do not resolve.
But, if I enter on the container and do ping pi-hole.net it connects without issue and the query will appear on the console log.
I tried starting the container with different settings, but the behaviour is always the same. I've tried:
- The repo script docker_run.sh
- The docker-compose.yml example
- Using docker run directly:
docker run -d --name pihole -e INTERFACE=en0 -e ServerIP=192.168.1.39 -e TZ=Europe/Madrid -e WEBPASSWORD=somePassword -e DNS1=1.1.1.1 -e DNS2=1.0.0.1 -p 80:80 -p 53:53/tcp -p 53:53/udp -p 443:443 -v ~/pihole/:/etc/pihole/ --dns=127.0.0.1 --dns=1.1.1.1 --cap-add=NET_ADMIN --restart=unless-stopped pihole/pihole:latest
(I added INTERFACE=en0 because by default it uses eth0 but I I do arp -a wifi interfece on my mac is en0. It does not work either way)
When changing computer dns ip to pihole (127.0.0.1 or local ip from other device) dns queries should be resolved and appear on the log.
I can access the console but only request made from inside the container are resolved.
pvnenqm4zr
I guess I'm missing something here, but I can't tell what. I've been trying to make it work for a few days without any luck. I hope someone can help me.
docker ps
CONTAINER ID IMAGE COMMAND CREATED STATUS PORTS NAMES
2129f760428b pihole/pihole:latest "/s6-init" About an hour ago Up About an hour (healthy) 0.0.0.0:53->53/tcp, 0.0.0.0:80->80/tcp, 0.0.0.0:443->443/tcp, 0.0.0.0:53->53/udp, 67/udp pihole
