has a enable botton, but when click its active for a few seconds
only is enabled for a few seconds then stops again
updating removes the browser block ext, i.e. the reason i'd like to downgrade, seeing a lot more ads after upgrading then before i upgraded
You are running an open resolver. Turn your Pi-hole off now.
dschaper@Mariner-10:~/shellcheck-stable$ dig pi.hole @xxx.xxx.xxx.xxx
; <<>> DiG 9.11.3-1ubuntu1.11-Ubuntu <<>> pi.hole @xxx.xxx.xxx.xxx
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 53953
;pi.hole. IN A
pi.hole. 2 IN A xxx.xxx.xxx.xxx
;; Query time: 73 msec
;; SERVER: xxx.xxx.xxx.xxx#53(xxx.xxx.xxx.xx)
;; WHEN: Mon Feb 24 13:45:34 PST 2020
;; MSG SIZE rcvd: 52
Edit for Mods: Yes, I am being intentionally blunt.
I don't follow this. What browser block ext are you referring to?
i'll work on blocking it with iptables later
Let us know when you do. We won't be providing any support until that time.
Later means your setup is all the time contributing to DDoS amplification attacks!
Do you have any idea of the security implications opening up your DNS, that you use for bank dealings etc, to the public Internet ?
Its hard to know every aspect in computing but please read up about it a little as these DDoS attacks are a very big nuisance.
EDIT: Consider setting up OpenVPN on server and clients to have Pi-hole everywhere with you:
Thanks.
Before:
pi@noads:~ $ dig +short @xxx.xxx.xxx.xxx txt test.openresolver.com
"open-resolver-detected"
After:
openresolver has been closed
Thank you.
Can you give us an update on what is work or not working and what you would like help with?
the adblocker for chrome and firefox
easylist.txt etc!!!
This is a Pi-hole forum. What Pi-hole issues can we help with?
I updated pihole before i knew about the changes in Remove adblock list style support: Remove adblock list style support by PromoFaux · Pull Request #2912 · pi-hole/pi-hole · GitHub
so i'm trying to downgrade so i could still use the adblock list style, because i'm seeing more ads since upgrading then before
The adblock style lists never worked. We removed the support for them since the actually broke things.
If you still really insist on needing to use the adblock style lists, then you can find versions of those lists that have been pre-parsed for DNS adblockers here:
[root@shawn-route ~]# pihole checkout master
Please note that changing branches severely alters your Pi-hole subsystems
Features that work on the master branch, may not on a development branch
This feature is NOT supported unless a Pi-hole developer explicitly asks!
Have you read and understood this? [y/N] y
[i] Shortcut "master" detected - checking out master branches...
[i] Pi-hole core
[✓] Switching to branch: 'master' from 'refs/heads/master'
[i] Already up-to-date.
[i] Web interface
[✓] Detected x86_64 architecture
pihole-FTL-linux-x86_64
[i] Running installer to upgrade your installation
[✓] Root user check
.ccccc:,.
:cccclll:. ..,,
:ccccclll. ;ooodc
'ccll:;ll .oooodc
.;cll.;;looo:.
[i] Enabling EPEL package repository (https://fedoraproject.org/wiki/EPEL)
Error: Unable to complete update, please contact support
curl -sSL https://install.pi-hole.net | bash
tried curl -sSL https://install.pi-hole.net | bash
still receive [i] Enabling EPEL package repository (EPEL - Fedora Project Wiki)
