Here is the information you requested:
[2021-11-23 14:14:15.382 782M] Finished final database update (stored 75 queries)
[2021-11-23 14:14:15.382 782M] Waiting for threads to join
[2021-11-23 14:14:15.382 782M] Thread telnet-IPv4 (0) is idle, terminating it.
[2021-11-23 14:14:15.383 782M] Thread telnet-IPv6 (1) is idle, terminating it.
[2021-11-23 14:14:15.383 782M] Thread telnet-socket (2) is idle, terminating it.
[2021-11-23 14:14:15.383 782M] Thread database (3) is idle, terminating it.
[2021-11-23 14:14:15.384 782M] Thread housekeeper (4) is idle, terminating it.
[2021-11-23 14:14:15.384 782M] Thread DNS client (5) is idle, terminating it.
[2021-11-23 14:14:15.385 782M] All threads joined
[2021-11-23 14:14:15.399 782M] ########## FTL terminated after 15h 38m 44s (code 0)! ##########
[2021-11-23 14:14:16.383 32739M] Using log file /var/log/pihole-FTL.log
[2021-11-23 14:14:16.384 32739M] ########## FTL started on HornDNS! ##########
[2021-11-23 14:14:16.384 32739M] FTL branch: master
[2021-11-23 14:14:16.384 32739M] FTL version: v5.11
[2021-11-23 14:14:16.384 32739M] FTL commit: a296265
[2021-11-23 14:14:16.384 32739M] FTL date: 2021-10-23 19:56:18 +0100
[2021-11-23 14:14:16.384 32739M] FTL user: pihole
[2021-11-23 14:14:16.384 32739M] Compiled for armv7hf (compiled on CI) using arm-linux-gnueabihf-gcc (Debian 6.3.0-18) 6.3.0 20170516
[2021-11-23 14:14:16.384 32739M] Creating mutex
[2021-11-23 14:14:16.386 32739M] Starting config file parsing (/etc/pihole/pihole-FTL.conf)
[2021-11-23 14:14:16.386 32739M] SOCKET_LISTENING: only local
[2021-11-23 14:14:16.386 32739M] AAAA_QUERY_ANALYSIS: Show AAAA queries
[2021-11-23 14:14:16.386 32739M] MAXDBDAYS: max age for stored queries is 365 days
[2021-11-23 14:14:16.386 32739M] RESOLVE_IPV6: Resolve IPv6 addresses
[2021-11-23 14:14:16.387 32739M] RESOLVE_IPV4: Resolve IPv4 addresses
[2021-11-23 14:14:16.387 32739M] DBINTERVAL: saving to DB file every minute
[2021-11-23 14:14:16.387 32739M] DBFILE: Using /etc/pihole/pihole-FTL.db
[2021-11-23 14:14:16.387 32739M] MAXLOGAGE: Importing up to 24.0 hours of log data
[2021-11-23 14:14:16.387 32739M] PRIVACYLEVEL: Set to 0
[2021-11-23 14:14:16.387 32739M] IGNORE_LOCALHOST: Show queries from localhost
[2021-11-23 14:14:16.387 32739M] BLOCKINGMODE: Null IPs for blocked domains
[2021-11-23 14:14:16.387 32739M] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2021-11-23 14:14:16.387 32739M] DBIMPORT: Importing history from database
[2021-11-23 14:14:16.387 32739M] PIDFILE: Using /run/pihole-FTL.pid
[2021-11-23 14:14:16.387 32739M] PORTFILE: Using /run/pihole-FTL.port
[2021-11-23 14:14:16.387 32739M] SOCKETFILE: Using /run/pihole/FTL.sock
[2021-11-23 14:14:16.387 32739M] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2021-11-23 14:14:16.387 32739M] MACVENDORDB: Using /etc/pihole/macvendor.db
[2021-11-23 14:14:16.388 32739M] GRAVITYDB: Using /etc/pihole/gravity.db
[2021-11-23 14:14:16.388 32739M] PARSE_ARP_CACHE: Active
[2021-11-23 14:14:16.388 32739M] CNAME_DEEP_INSPECT: Active
[2021-11-23 14:14:16.388 32739M] DELAY_STARTUP: No delay requested.
[2021-11-23 14:14:16.388 32739M] BLOCK_ESNI: Enabled, blocking _esni.{blocked domain}
[2021-11-23 14:14:16.388 32739M] NICE: Set process niceness to -10 (default)
[2021-11-23 14:14:16.388 32739M] MAXNETAGE: Removing IP addresses and host names from network table after 365 days
[2021-11-23 14:14:16.388 32739M] NAMES_FROM_NETDB: Enabled, trying to get names from network database
[2021-11-23 14:14:16.388 32739M] EDNS0_ECS: Overwrite client from ECS information
[2021-11-23 14:14:16.388 32739M] REFRESH_HOSTNAMES: Periodically refreshing IPv4 names
[2021-11-23 14:14:16.388 32739M] RATE_LIMIT: Rate-limiting client making more than 1000 queries in 60 seconds
[2021-11-23 14:14:16.388 32739M] REPLY_ADDR4: Automatic interface-dependent detection of address
[2021-11-23 14:14:16.388 32739M] REPLY_ADDR6: Automatic interface-dependent detection of address
[2021-11-23 14:14:16.388 32739M] SHOW_DNSSEC: Enabled, showing automatically generated DNSSEC queries
[2021-11-23 14:14:16.388 32739M] MOZILLA_CANARY: Enabled
[2021-11-23 14:14:16.389 32739M] PIHOLE_PTR: internal PTR generation enabled (pi.hole)
[2021-11-23 14:14:16.389 32739M] ADDR2LINE: Enabled
[2021-11-23 14:14:16.389 32739M] REPLY_WHEN_BUSY: Permit queries when the database is busy
[2021-11-23 14:14:16.389 32739M] BLOCK_TTL: 2 seconds
[2021-11-23 14:14:16.389 32739M] BLOCK_ICLOUD_PR: Enabled
[2021-11-23 14:14:16.389 32739M] Finished config file parsing
[2021-11-23 14:14:16.390 32739M] Database version is 9
[2021-11-23 14:14:16.390 32739M] Resizing "FTL-strings" from 40960 to (81920 * 1) == 81920 (/dev/shm: 1.1MB used, 484.0MB total, FTL uses 1.1MB)
[2021-11-23 14:14:16.391 32739M] Imported 0 alias-clients
[2021-11-23 14:14:16.391 32739M] Database successfully initialized
[2021-11-23 14:14:16.394 32739M] New upstream server: 8.8.4.4:53 (0/256)
[2021-11-23 14:14:16.398 32739M] New upstream server: 8.8.8.8:53 (1/256)
[2021-11-23 14:14:16.431 32739M] Resizing "FTL-domains" from 4096 to (512 * 16) == 8192 (/dev/shm: 1.1MB used, 484.0MB total, FTL uses 1.1MB)
[2021-11-23 14:14:16.448 32739M] Resizing "FTL-queries" from 180224 to (8192 * 44) == 360448 (/dev/shm: 1.1MB used, 484.0MB total, FTL uses 1.1MB)
[2021-11-23 14:14:16.453 32739M] Resizing "FTL-domains" from 8192 to (768 * 16) == 12288 (/dev/shm: 1.3MB used, 484.0MB total, FTL uses 1.3MB)
[2021-11-23 14:14:16.499 32739M] Resizing "FTL-queries" from 360448 to (12288 * 44) == 540672 (/dev/shm: 1.3MB used, 484.0MB total, FTL uses 1.3MB)
[2021-11-23 14:14:16.548 32739M] Resizing "FTL-domains" from 12288 to (1024 * 16) == 16384 (/dev/shm: 1.5MB used, 484.0MB total, FTL uses 1.5MB)
[2021-11-23 14:14:16.557 32739M] Resizing "FTL-queries" from 540672 to (16384 * 44) == 720896 (/dev/shm: 1.5MB used, 484.0MB total, FTL uses 1.5MB)
[2021-11-23 14:14:16.620 32739M] Resizing "FTL-queries" from 720896 to (20480 * 44) == 901120 (/dev/shm: 1.7MB used, 484.0MB total, FTL uses 1.7MB)
[2021-11-23 14:14:16.754 32739M] Resizing "FTL-queries" from 901120 to (24576 * 44) == 1081344 (/dev/shm: 1.9MB used, 484.0MB total, FTL uses 1.9MB)
[2021-11-23 14:14:16.823 32739M] Resizing "FTL-domains" from 16384 to (1280 * 16) == 20480 (/dev/shm: 2.1MB used, 484.0MB total, FTL uses 2.0MB)
[2021-11-23 14:14:16.890 32739M] Resizing "FTL-queries" from 1081344 to (28672 * 44) == 1261568 (/dev/shm: 2.1MB used, 484.0MB total, FTL uses 2.0MB)
[2021-11-23 14:14:17.049 32739M] Resizing "FTL-queries" from 1261568 to (32768 * 44) == 1441792 (/dev/shm: 2.2MB used, 484.0MB total, FTL uses 2.2MB)
[2021-11-23 14:14:17.208 32739M] Resizing "FTL-queries" from 1441792 to (36864 * 44) == 1622016 (/dev/shm: 2.4MB used, 484.0MB total, FTL uses 2.4MB)
[2021-11-23 14:14:17.309 32739M] Resizing "FTL-domains" from 20480 to (1536 * 16) == 24576 (/dev/shm: 2.6MB used, 484.0MB total, FTL uses 2.6MB)
[2021-11-23 14:14:17.368 32739M] Resizing "FTL-queries" from 1622016 to (40960 * 44) == 1802240 (/dev/shm: 2.6MB used, 484.0MB total, FTL uses 2.6MB)
[2021-11-23 14:14:17.524 32739M] Resizing "FTL-queries" from 1802240 to (45056 * 44) == 1982464 (/dev/shm: 2.8MB used, 484.0MB total, FTL uses 2.8MB)
[2021-11-23 14:14:17.684 32739M] Resizing "FTL-queries" from 1982464 to (49152 * 44) == 2162688 (/dev/shm: 3.0MB used, 484.0MB total, FTL uses 3.0MB)
[2021-11-23 14:14:17.840 32739M] Resizing "FTL-queries" from 2162688 to (53248 * 44) == 2342912 (/dev/shm: 3.1MB used, 484.0MB total, FTL uses 3.1MB)
[2021-11-23 14:14:18.007 32739M] Resizing "FTL-queries" from 2342912 to (57344 * 44) == 2523136 (/dev/shm: 3.3MB used, 484.0MB total, FTL uses 3.3MB)
[2021-11-23 14:14:18.055 32739M] Resizing "FTL-domains" from 24576 to (1792 * 16) == 28672 (/dev/shm: 3.5MB used, 484.0MB total, FTL uses 3.5MB)
[2021-11-23 14:14:18.214 32739M] Resizing "FTL-queries" from 2523136 to (61440 * 44) == 2703360 (/dev/shm: 3.5MB used, 484.0MB total, FTL uses 3.5MB)
[2021-11-23 14:14:18.375 32739M] Resizing "FTL-queries" from 2703360 to (65536 * 44) == 2883584 (/dev/shm: 3.7MB used, 484.0MB total, FTL uses 3.7MB)
[2021-11-23 14:14:18.541 32739M] Resizing "FTL-queries" from 2883584 to (69632 * 44) == 3063808 (/dev/shm: 3.9MB used, 484.0MB total, FTL uses 3.9MB)
[2021-11-23 14:14:18.700 32739M] Resizing "FTL-queries" from 3063808 to (73728 * 44) == 3244032 (/dev/shm: 4.1MB used, 484.0MB total, FTL uses 4.0MB)
[2021-11-23 14:14:18.767 32739M] Resizing "FTL-domains" from 28672 to (2048 * 16) == 32768 (/dev/shm: 4.2MB used, 484.0MB total, FTL uses 4.2MB)
[2021-11-23 14:14:18.884 32739M] Resizing "FTL-queries" from 3244032 to (77824 * 44) == 3424256 (/dev/shm: 4.2MB used, 484.0MB total, FTL uses 4.2MB)
[2021-11-23 14:14:19.072 32739M] Resizing "FTL-queries" from 3424256 to (81920 * 44) == 3604480 (/dev/shm: 4.4MB used, 484.0MB total, FTL uses 4.4MB)
[2021-11-23 14:14:19.271 32739M] Resizing "FTL-queries" from 3604480 to (86016 * 44) == 3784704 (/dev/shm: 4.6MB used, 484.0MB total, FTL uses 4.6MB)
[2021-11-23 14:14:19.475 32739M] Resizing "FTL-queries" from 3784704 to (90112 * 44) == 3964928 (/dev/shm: 4.8MB used, 484.0MB total, FTL uses 4.8MB)
[2021-11-23 14:14:19.613 32739M] Resizing "FTL-strings" from 81920 to (122880 * 1) == 122880 (/dev/shm: 5.0MB used, 484.0MB total, FTL uses 4.9MB)
[2021-11-23 14:14:19.651 32739M] Resizing "FTL-domains" from 32768 to (2304 * 16) == 36864 (/dev/shm: 5.0MB used, 484.0MB total, FTL uses 5.0MB)
[2021-11-23 14:14:19.713 32739M] Resizing "FTL-queries" from 3964928 to (94208 * 44) == 4145152 (/dev/shm: 5.0MB used, 484.0MB total, FTL uses 5.0MB)
[2021-11-23 14:14:19.882 32739M] Resizing "FTL-queries" from 4145152 to (98304 * 44) == 4325376 (/dev/shm: 5.2MB used, 484.0MB total, FTL uses 5.2MB)
[2021-11-23 14:14:19.984 32739M] Resizing "FTL-domains" from 36864 to (2560 * 16) == 40960 (/dev/shm: 5.4MB used, 484.0MB total, FTL uses 5.3MB)
[2021-11-23 14:14:20.038 32739M] Resizing "FTL-queries" from 4325376 to (102400 * 44) == 4505600 (/dev/shm: 5.4MB used, 484.0MB total, FTL uses 5.4MB)
[2021-11-23 14:14:20.187 32739M] Resizing "FTL-queries" from 4505600 to (106496 * 44) == 4685824 (/dev/shm: 5.5MB used, 484.0MB total, FTL uses 5.5MB)
[2021-11-23 14:14:20.294 32739M] Resizing "FTL-queries" from 4685824 to (110592 * 44) == 4866048 (/dev/shm: 5.7MB used, 484.0MB total, FTL uses 5.7MB)
[2021-11-23 14:14:20.321 32739M] Resizing "FTL-domains" from 40960 to (2816 * 16) == 45056 (/dev/shm: 5.9MB used, 484.0MB total, FTL uses 5.9MB)
[2021-11-23 14:14:20.390 32739M] Resizing "FTL-queries" from 4866048 to (114688 * 44) == 5046272 (/dev/shm: 5.9MB used, 484.0MB total, FTL uses 5.9MB)
[2021-11-23 14:14:20.492 32739M] Resizing "FTL-queries" from 5046272 to (118784 * 44) == 5226496 (/dev/shm: 6.1MB used, 484.0MB total, FTL uses 6.1MB)
[2021-11-23 14:14:20.594 32739M] Resizing "FTL-queries" from 5226496 to (122880 * 44) == 5406720 (/dev/shm: 6.3MB used, 484.0MB total, FTL uses 6.3MB)
[2021-11-23 14:14:20.695 32739M] Resizing "FTL-queries" from 5406720 to (126976 * 44) == 5586944 (/dev/shm: 6.5MB used, 484.0MB total, FTL uses 6.4MB)
[2021-11-23 14:14:20.801 32739M] Resizing "FTL-queries" from 5586944 to (131072 * 44) == 5767168 (/dev/shm: 6.6MB used, 484.0MB total, FTL uses 6.6MB)
[2021-11-23 14:14:20.907 32739M] Resizing "FTL-queries" from 5767168 to (135168 * 44) == 5947392 (/dev/shm: 6.8MB used, 484.0MB total, FTL uses 6.8MB)
[2021-11-23 14:14:21.004 32739M] Resizing "FTL-queries" from 5947392 to (139264 * 44) == 6127616 (/dev/shm: 7.0MB used, 484.0MB total, FTL uses 7.0MB)
[2021-11-23 14:14:21.081 32739M] Resizing "FTL-domains" from 45056 to (3072 * 16) == 49152 (/dev/shm: 7.2MB used, 484.0MB total, FTL uses 7.2MB)
[2021-11-23 14:14:21.133 32739M] Resizing "FTL-queries" from 6127616 to (143360 * 44) == 6307840 (/dev/shm: 7.2MB used, 484.0MB total, FTL uses 7.2MB)
[2021-11-23 14:14:21.323 32739M] Resizing "FTL-queries" from 6307840 to (147456 * 44) == 6488064 (/dev/shm: 7.4MB used, 484.0MB total, FTL uses 7.3MB)
[2021-11-23 14:14:21.514 32739M] Resizing "FTL-queries" from 6488064 to (151552 * 44) == 6668288 (/dev/shm: 7.5MB used, 484.0MB total, FTL uses 7.5MB)
[2021-11-23 14:14:21.687 32739M] Resizing "FTL-queries" from 6668288 to (155648 * 44) == 6848512 (/dev/shm: 7.7MB used, 484.0MB total, FTL uses 7.7MB)
[2021-11-23 14:14:21.882 32739M] Resizing "FTL-queries" from 6848512 to (159744 * 44) == 7028736 (/dev/shm: 7.9MB used, 484.0MB total, FTL uses 7.9MB)
[2021-11-23 14:14:22.069 32739M] Resizing "FTL-queries" from 7028736 to (163840 * 44) == 7208960 (/dev/shm: 8.1MB used, 484.0MB total, FTL uses 8.1MB)
[2021-11-23 14:14:22.260 32739M] Resizing "FTL-queries" from 7208960 to (167936 * 44) == 7389184 (/dev/shm: 8.3MB used, 484.0MB total, FTL uses 8.2MB)
[2021-11-23 14:14:22.329 32739M] Resizing "FTL-domains" from 49152 to (3328 * 16) == 53248 (/dev/shm: 8.4MB used, 484.0MB total, FTL uses 8.4MB)
[2021-11-23 14:14:22.429 32739M] Resizing "FTL-queries" from 7389184 to (172032 * 44) == 7569408 (/dev/shm: 8.4MB used, 484.0MB total, FTL uses 8.4MB)
[2021-11-23 14:14:22.618 32739M] Resizing "FTL-queries" from 7569408 to (176128 * 44) == 7749632 (/dev/shm: 8.6MB used, 484.0MB total, FTL uses 8.6MB)
[2021-11-23 14:14:22.847 32739M] Resizing "FTL-queries" from 7749632 to (180224 * 44) == 7929856 (/dev/shm: 8.8MB used, 484.0MB total, FTL uses 8.8MB)
[2021-11-23 14:14:22.873 32739M] Resizing "FTL-strings" from 122880 to (163840 * 1) == 163840 (/dev/shm: 9.0MB used, 484.0MB total, FTL uses 9.0MB)
[2021-11-23 14:14:23.030 32739M] Resizing "FTL-queries" from 7929856 to (184320 * 44) == 8110080 (/dev/shm: 9.0MB used, 484.0MB total, FTL uses 9.0MB)
[2021-11-23 14:14:23.213 32739M] Resizing "FTL-queries" from 8110080 to (188416 * 44) == 8290304 (/dev/shm: 9.2MB used, 484.0MB total, FTL uses 9.2MB)
[2021-11-23 14:14:23.398 32739M] Resizing "FTL-queries" from 8290304 to (192512 * 44) == 8470528 (/dev/shm: 9.4MB used, 484.0MB total, FTL uses 9.4MB)
[2021-11-23 14:14:23.403 32739M] Resizing "FTL-domains" from 53248 to (3584 * 16) == 57344 (/dev/shm: 9.6MB used, 484.0MB total, FTL uses 9.6MB)
[2021-11-23 14:14:23.591 32739M] Resizing "FTL-queries" from 8470528 to (196608 * 44) == 8650752 (/dev/shm: 9.6MB used, 484.0MB total, FTL uses 9.6MB)
[2021-11-23 14:14:23.754 32739M] Resizing "FTL-queries" from 8650752 to (200704 * 44) == 8830976 (/dev/shm: 9.7MB used, 484.0MB total, FTL uses 9.7MB)
[2021-11-23 14:14:23.930 32739M] Resizing "FTL-queries" from 8830976 to (204800 * 44) == 9011200 (/dev/shm: 9.9MB used, 484.0MB total, FTL uses 9.9MB)
[2021-11-23 14:14:24.093 32739M] Resizing "FTL-queries" from 9011200 to (208896 * 44) == 9191424 (/dev/shm: 10.1MB used, 484.0MB total, FTL uses 10.1MB)
[2021-11-23 14:14:24.253 32739M] Resizing "FTL-queries" from 9191424 to (212992 * 44) == 9371648 (/dev/shm: 10.3MB used, 484.0MB total, FTL uses 10.3MB)
[2021-11-23 14:14:24.418 32739M] Resizing "FTL-queries" from 9371648 to (217088 * 44) == 9551872 (/dev/shm: 10.5MB used, 484.0MB total, FTL uses 10.5MB)
[2021-11-23 14:14:24.564 32739M] Resizing "FTL-queries" from 9551872 to (221184 * 44) == 9732096 (/dev/shm: 10.6MB used, 484.0MB total, FTL uses 10.6MB)
[2021-11-23 14:14:24.747 32739M] Resizing "FTL-queries" from 9732096 to (225280 * 44) == 9912320 (/dev/shm: 10.8MB used, 484.0MB total, FTL uses 10.8MB)
[2021-11-23 14:14:24.923 32739M] Resizing "FTL-queries" from 9912320 to (229376 * 44) == 10092544 (/dev/shm: 11.0MB used, 484.0MB total, FTL uses 11.0MB)
[2021-11-23 14:14:25.073 32739M] Resizing "FTL-queries" from 10092544 to (233472 * 44) == 10272768 (/dev/shm: 11.2MB used, 484.0MB total, FTL uses 11.2MB)
[2021-11-23 14:14:25.233 32739M] Resizing "FTL-domains" from 57344 to (3840 * 16) == 61440 (/dev/shm: 11.4MB used, 484.0MB total, FTL uses 11.4MB)
[2021-11-23 14:14:25.237 32739M] Resizing "FTL-queries" from 10272768 to (237568 * 44) == 10452992 (/dev/shm: 11.4MB used, 484.0MB total, FTL uses 11.4MB)
[2021-11-23 14:14:25.378 32739M] Imported 236341 queries from the long-term database
[2021-11-23 14:14:25.379 32739M] -> Total DNS queries: 236341
[2021-11-23 14:14:25.379 32739M] -> Cached DNS queries: 179842
[2021-11-23 14:14:25.380 32739M] -> Forwarded DNS queries: 36879
[2021-11-23 14:14:25.380 32739M] -> Blocked DNS queries: 18572
[2021-11-23 14:14:25.380 32739M] -> Unknown DNS queries: 1
[2021-11-23 14:14:25.380 32739M] -> Unique domains: 3605
[2021-11-23 14:14:25.380 32739M] -> Unique clients: 29
[2021-11-23 14:14:25.380 32739M] -> Known forward destinations: 2
[2021-11-23 14:14:25.380 32739M] Successfully accessed setupVars.conf
[2021-11-23 14:14:25.382 32739M] listening on 0.0.0.0 port 53
[2021-11-23 14:14:25.383 32739M] listening on :: port 53
[2021-11-23 14:14:25.388 306M] PID of FTL process: 306
[2021-11-23 14:14:25.389 306M] INFO: FTL is running as user pihole (UID 999)
[2021-11-23 14:14:25.389 306/T307] Listening on port 4711 for incoming IPv4 telnet connections
[2021-11-23 14:14:25.390 306/T308] Listening on port 4711 for incoming IPv6 telnet connections
[2021-11-23 14:14:25.390 306/T309] Listening on Unix socket
[2021-11-23 14:14:25.391 306M] Reloading DNS cache
[2021-11-23 14:14:25.533 306M] Blocking status is enabled
[2021-11-23 14:14:26.526 306/T310] Compiled 0 whitelist and 14 blacklist regex filters for 29 clients in 108.3 msec
