I changed the slaac private to slaac hardware and rebooted the pi.
I ran pihole -r and pihole -d thereafter. I still get the same error. When i edit /etc/pihole/setupVars.conf I find IPV6_ADDRES= to be empty.
I will try filling in the ipv6 address i have now.
pihole -d says ipv6 is configured now. I do however get some error messages for resolving ipv6 addresses.
debug token: ohavomyn0q
RamSet
May 30, 2018, 8:25pm
24
see if nslookup ipv6.google.com is resolving properly .
Also nslookup -query=AAAA flurry.com should give you your pi-hole IPV6 ip
On my pi with pihole nslookup ipv6.google.com gives:
Server: 127.0.0.1
Address: 127.0.0.1#53
Non-authoritative answer:
ipv6.google.com canonical name = ipv6.l.google.com.
And nslookup -query=AAAA flurry.com does not resolve either. Whereas nslookup -query=A flurry.com does resolve to my pi's local ipv4 address.
Now when I run these commands from my desktop computer I get the following:
gives
Server: 127.0.1.1
Address: 127.0.1.1#53
*** Can't find flurry.com: No answer
Authoritative answers can be found from:
flurry.com
origin = hidden-master.yahoo.com
mail addr = hostmaster.yahoo-inc.com
serial = 2018053100
refresh = 28800
retry = 7200
expire = 604800
minimum = 600
And nslookup -query=A flurry.com
gives
Server: 127.0.1.1
Address: 98.136.103.26
Address: 74.6.136.153
Address: 212.82.100.153
RamSet
May 31, 2018, 8:16pm
26
AAAA is the IPV6 query. If it doesn't resolve it means that an IPV6 DNS was not queried (in this case, found).
127.0.1.1 is strange. That request should go through the DNS server and not your loopback IP.
(What are your DNS settings on the client/desktop ?)
berendho:
gives
Server: 127.0.1.1
This result should return the pi-hole IP not the actual IPs of that domain. This shows that your DNS request leaked and it didn't hit the pi-hole DNS.
This might have been a caching issue on my desktop pc.
Running nmcli dev show | grep DNS gives
IP4.DNS[1]: 192.168.1.202
IP6.DNS[1]: 2001:b88:1002::10
IP6.DNS[2]: 2001:b88:1202::10
IP6.DNS[3]: 2001:730:3e42:1000::53
When I ran nslookup -query=A flurry.com another two times, the second time it resolved to
Server: 127.0.1.1
Address: 192.168.1.202
It looks like my ipv6 dns server is still a public dns from my provider. I have the pihole as my dhcp server with IPV6 support on.
RamSet
May 31, 2018, 9:09pm
28
You are using a combination of DNS servers here.
Have a look at this:
Reduced Ad Blocking Capability
The main reason you should Pi-hole as your only DNS server is that you will see increased performance in the blocking of ads.
If you have two DNS servers (Pi-hole and something else), your network clients may not always query Pi-hole for name resolution. If a query happens to be answered from a non-Pi-hole DNS server, your block lists will not apply (since that DNS server doesn't know about them).
All Queries Need To Go Through Pi-hole First
Since other DNS serv…
What you need to make sure is that your IPV6 DNS server, matched the IPV6 IP of the pi-hole device.
I guess my router (given by my provider) is somehow still advertising my providers ipv6 DNS server address in my local network. I know the thing is buggy since it cannot even reliably do static addresses for DHCP.
RamSet
May 31, 2018, 9:19pm
30
You could use Pi-hole as your DHCP server ...
I have already done this and disabled the one my router
system
Closed
June 22, 2018, 6:00am
32
