@PromoFaux Can we build a pihole container (v5) with only FTL on a custom branch (fix/many_clients)? The answer is probably Yes but I always forget how to do this.
No. This is only a symptom of FTL crash (or in some cases, FTL is still restarting), not a cause.
This error only means PHP is trying to connect to FTL, but FTL is not available.
I'm sorry but the problem isn't with the restarted the container, but after comand excecution. pihole checkout ftl fix/many_clients
I don't see any improvement after comand excecution, the container remains in an unhealty state on portainer and from the pihole interface I see that the state remains inactive
Okay, so it seems there is some confusion here. I asked you to check out the branch fix/many_clients and that worked according to your screenshots. Then you have seen another crash but the crash log was reporting FTL is running on master, not the custom branch fix/many_clients so I figured the container was somehow reset (as you didn't check out master again, did you?).
As your screenshot shows, pihole-FTL is restarted during the checkout procedure so it should start running immediately. So I guess it crashes again shortly after so that the status has no chance to change at all? Please provide a new crash report from FTL.log and we will manage to get there eventually.
I am very sorry this is taking so long for you but - so far - it seems you are the only user experiencing this and us not being able to reproduce this makes it obviously very hard to fix it...
However, looking at your uploaded FTL.log file, there is actually no problem and FTL is running fine so this display may be a cosmetic issue, only. Does your Pi-hole respond to DNS queries as you'd expect it to?
in the meantime, I thank you very much for all the effort you have put in, especially you @DL6ER if you have any updates regarding my case history, I'll be waiting.
