The issue I am facing:
I have a docker compose file for pihole as follows:
pihole:
container_name: pihole
image: pihole/pihole:latest
hostname: kiwi.hole
ports:
- "53:53/tcp"
- "53:53/udp"
# - "67:67/udp" # Only required if you are using Pi-hole as your DHCP server
- "9999:80/tcp"
environment:
TZ: "America/Toronto"
WEBPASSWORD: ''
VIRTUAL_HOST: 'kiwi.hole'
DNS_BOGUS_PRIV: 'true'
DNS_FQDN_REQUIRED: 'true'
REV_SERVER: 'true'
REV_SERVER_DOMAIN: 'local'
REV_SERVER_TARGET: '192.168.1.1'
REV_SERVER_CIDR: '192.168.1.0/24'
labels:
com.centurylinklabs.watchtower.enable: "true"
volumes:
- "/media/usb/pihole/etc/etc-pihole:/etc/pihole"
- "/media/usb/pihole/etc/etc-dnsmasq.d:/etc/dnsmasq.d"
# https://github.com/pi-hole/docker-pi-hole#note-on-capabilities
cap_add:
- NET_ADMIN # Recommended but not required (DHCP needs NET_ADMIN)
restart: always
When I start pihole I get errors related to permissions.
pihole | chown: changing ownership of '/etc/pihole/dhcp.leases': Operation not permitted
pihole | chown: changing ownership of '/etc/pihole': Operation not permitted
When I specify a volume that is on the local system I do not see errors and some of the files are owned by systemd-coredump. My Fstab is as follows and I have tried with and without umask=000 and the issues are the same.
UUID=B2AB-22A4 /media/usb vfat auto,umask=000,defaults 0 2
I need the volume on a usb because my main drive is running out of space (thin client with only 12GB of space).
Details about my system:
Think client Dell Wyse 3040 running ubuntu server.
As detailed above, I am trying to modify the volume directory.
I have a feeling I just need to add some user to some group or something or my fstab mount is wrong... docker does not seem to have any issues modifying the permissions of files in the volume when it is on the local disk so this is my assumption.
Thanks for any help offered!
