Hello, i can't run my Pihole
xxx@raspberrypi:~ $ sudo pihole-FTL
[sudo] Mot de passe de xxx :
dnsmasq: failed to create listening socket for port 53: Address already in use
xxx@raspberrypi:~ $ sudo netstat -nltup | grep 'Proto\|:53 \|:67 \|:80 \|:471'
Proto Recv-Q Send-Q Adresse locale Adresse distante Etat PID/Program name
tcp 0 0 0.0.0.0:80 0.0.0.0:* LISTEN 546/lighttpd
tcp 0 0 127.0.0.53:53 0.0.0.0:* LISTEN 268/systemd-resolve
tcp6 0 0 :::80 :::* LISTEN 546/lighttpd
udp 0 0 127.0.0.53:53 0.0.0.0:* 268/systemd-resolve
This is my pihole -d :
*** [ INITIALIZING ]
[i] 2020-01-12:04:33:24 debug log has been initialized.
[i] Core: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-ge41c4b5
[i] Web: v4.3.2 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] Branch: master
[i] Commit: v4.3.2-0-g38d8e77
[✓] FTL: v4.3.1 (https://discourse.pi-hole.net/t/how-do-i-update-pi-hole/249)
[i] 1.4.53
[i] 7.3.11
[✓] Raspbian GNU/Linux 10 (buster)
*** [ DIAGNOSING ]: SELinux
[i] SELinux not detected
*** [ DIAGNOSING ]: Processor
[✓] armv7l
192.168.0.245/24 matches the IP found in /etc/pihole/setupVars.conf
2a01:e0a:28e:4a50:ae13:3ffe:7707:5f14 matches the IP found in /etc/pihole/setupVars.conf
::ffff:192.168.0.245 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
fe80::4383:8128:840:7363 does not match the IP found in /etc/pihole/setupVars.conf (https://discourse.pi-hole.net/t/use-ipv6-ula-addresses-for-pi-hole/2127)
[i] Default IPv4 gateway: 192.168.0.254
* Pinging 192.168.0.254...
[✓] Gateway responded.
*:5355 systemd-re (IPv4)
*:5355 systemd-re (IPv6)
[127.0.0.53:53] is in use by pihole-FTL
*:4854 sshd (IPv4)
*:4854 sshd (IPv6)
[*:80] is in use by lighttpd
[✗] Failed to resolve 3130320.fls.doubleclick.net via localhost (127.0.0.1)
[✗] Failed to resolve 3130320.fls.doubleclick.net via Pi-hole (192.168.0.245)
[✓] doubleclick.com is 216.58.213.174 via a remote, public DNS server (8.8.8.8)
[✗] Failed to resolve banners.sandralatina.com via localhost (::1)
[✗] Failed to resolve banners.sandralatina.com via Pi-hole (2a01:e0a:28e:4a50:ae13:3ffe:7707:5f14)
[✗] Failed to resolve doubleclick.com via a remote, public DNS server (2001:4860:4860::8888)
[✓] lighttpd daemon is active
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=192.168.0.245/24
IPV6_ADDRESS=2a01:e0a:28e:4a50:ae13:3ffe:7707:5f14
QUERY_LOGGING=true
INSTALL_WEB_SERVER=true
INSTALL_WEB_INTERFACE=true
LIGHTTPD_ENABLED=true
DNSMASQ_LISTENING=single
PIHOLE_DNS_1=208.67.222.222
PIHOLE_DNS_2=208.67.220.220
PIHOLE_DNS_3=2620:119:35::35
PIHOLE_DNS_4=2620:119:53::53
DNS_FQDN_REQUIRED=true
DNS_BOGUS_PRIV=true
DNSSEC=false
CONDITIONAL_FORWARDING=false
BLOCKING_ENABLED=true
[✓] Block page X-Header: X-Pi-hole: A black hole for Internet advertisements.
[✓] Web interface X-Header: X-Pi-hole: The Pi-hole Web interface is working!
-rw-r--r-- 1 root root 2679606 janv. 12 02:52 /etc/pihole/gravity.list
0.0.0.0
0.nextyourcontent.com
0.r.msn.com
0.start.bz
zzz.clickbank.net
zzzezeroe.fr
zzzpooeaz-france.com
zzzrtrcm2.com
-rw-r--r-- 1 root root 313 janv. 12 04:14 /etc/pihole/adlists.list
-rw-r--r-- 1 root root 144 janv. 12 02:52 /etc/pihole/local.list
192.168.0.245 raspberrypi
2a01:e0a:28e:4a50:ae13:3ffe:7707:5f14 raspberrypi
192.168.0.245 pi.hole
2a01:e0a:28e:4a50:ae13:3ffe:7707:5f14 pi.hole
-rw-r--r-- 1 root root 234 janv. 11 02:12 /etc/pihole/logrotate
/var/log/pihole.log {
su root root
daily
copytruncate
rotate 5
compress
delaycompress
notifempty
nomail
/var/log/pihole-FTL.log {
su root root
weekly
copytruncate
rotate 3
compress
delaycompress
notifempty
nomail
-rw-r--r-- 1 root root 1458 janv. 12 04:12 /etc/dnsmasq.d/01-pihole.conf
localise-queries
no-resolv
cache-size=10000
log-queries
local-ttl=2
log-async
server=208.67.222.222
server=208.67.220.220
server=2620:119:35::35
server=2620:119:53::53
bogus-priv
interface=eth0
-rw-r--r-- 1 root root 3499 janv. 11 02:12 /etc/lighttpd/lighttpd.conf
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "/pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
mimetype.assign = ( ".png" => "image/png",
".jpg" => "image/jpeg",
".jpeg" => "image/jpeg",
".html" => "text/html",
".js" => "application/javascript",
".json" => "application/json",
".txt" => "text/plain",
".svg" => "image/svg+xml" )
' 2>/dev/null"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
$HTTP["url"] =~ ".ttf$" {
url.access-deny = ("")
-rw-r--r-- 1 root root 1703 janv. 11 02:12 /etc/cron.d/pihole
43 3 * * 7 root PATH="$PATH:/usr/local/bin/" pihole updateGravity >/var/log/pihole_updateGravity.log || cat /var/log/pihole_updateGravity.log
00 00 * * * root PATH="$PATH:/usr/local/bin/" pihole flush once quiet
*/10 * * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker local
4 13 * * * root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote
@reboot root PATH="$PATH:/usr/local/bin/" pihole updatechecker remote reboot
-rw-r--r-- 1 www-data www-data 1450 janv. 12 04:00 /var/log/lighttpd/error.log
2020-01-12 00:06:25: (server.c.1759) logfiles cycled UID = 0 PID = 656
2020-01-12 00:39:32: (server.c.2059) server stopped by UID = 0 PID = 1
2020-01-12 00:39:45: (server.c.1464) server started (lighttpd/1.4.53)
2020-01-12 00:39:45: (server.c.1493) WARNING: unknown config-key: alias.url (ignored)
2020-01-12 03:41:27: (server.c.2059) server stopped by UID = 0 PID = 1
2020-01-12 03:41:39: (server.c.1464) server started (lighttpd/1.4.53)
2020-01-12 03:41:39: (server.c.1493) WARNING: unknown config-key: alias.url (ignored)
2020-01-12 03:47:04: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2020-01-12 03:50:15: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2020-01-12 03:54:36: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2020-01-12 04:00:03: (mod_fastcgi.c.421) FastCGI-stderr: PHP Warning: unlink(../custom_disable_timer): No such file or directory in /var/www/html/admin/api.php on line 47
2020-01-12 04:00:11: (server.c.2059) server stopped by UID = 0 PID = 1
2020-01-12 04:00:24: (server.c.1464) server started (lighttpd/1.4.53)
2020-01-12 04:00:24: (server.c.1493) WARNING: unknown config-key: alias.url (ignored)
-rw-r--r-- 1 pihole pihole 46863 janv. 12 04:17 /var/log/pihole-FTL.log
[2020-01-12 02:13:00.041 2312] SQLite3 message: statement aborts at 34: [INSERT INTO queries VALUES (NULL,?,?,?,?,?,?)] attempt to write a readonly database (8)
[2020-01-12 02:13:00.042 2312] save_to_DB() - SQL error (8): attempt to write a readonly database
[2020-01-12 02:13:00.042 2312] SQLite3 message: statement aborts at 34: [INSERT INTO queries VALUES (NULL,?,?,?,?,?,?)] attempt to write a readonly database (8)
[2020-01-12 02:13:00.042 2312] save_to_DB() - exiting due to too many errors
[2020-01-12 02:14:00.033 2312] SQLite3 message: statement aborts at 34: [INSERT INTO queries VALUES (NULL,?,?,?,?,?,?)] attempt to write a readonly database (8)
[2020-01-12 02:14:00.033 2312] save_to_DB() - SQL error (8): attempt to write a readonly database
[2020-01-12 02:14:00.034 2312] SQLite3 message: statement aborts at 34: [INSERT INTO queries VALUES (NULL,?,?,?,?,?,?)] attempt to write a readonly database (8)
[2020-01-12 02:14:00.034 2312] save_to_DB() - SQL error (8): attempt to write a readonly database
[2020-01-12 02:14:00.034 2312] save_to_DB() - exiting due to too many errors
[2020-01-12 02:15:00.027 2312] SQLite3 message: statement aborts at 34: [INSERT INTO queries VALUES (NULL,?,?,?,?,?,?)] attempt to write a readonly database (8)
[2020-01-12 02:15:00.028 2312] save_to_DB() - SQL error (8): attempt to write a readonly database
[2020-01-12 02:15:00.028 2312] SQLite3 message: statement aborts at 34: [INSERT INTO queries VALUES (NULL,?,?,?,?,?,?)] attempt to write a readonly database (8)
[2020-01-12 02:15:00.028 2312] save_to_DB() - exiting due to too many errors
[2020-01-12 02:16:00.015 2312] SQLite3 message: statement aborts at 34: [INSERT INTO queries VALUES (NULL,?,?,?,?,?,?)] attempt to write a readonly database (8)
[2020-01-12 02:16:00.015 2312] save_to_DB() - SQL error (8): attempt to write a readonly database
[2020-01-12 02:16:00.015 2312] save_to_DB() - exiting due to too many errors
[2020-01-12 02:17:00.005 2312] SQLite3 message: statement aborts at 34: [INSERT INTO queries VALUES (NULL,?,?,?,?,?,?)] attempt to write a readonly database (8)
[2020-01-12 02:17:00.005 2312] save_to_DB() - SQL error (8): attempt to write a readonly database
[2020-01-12 02:17:00.005 2312] save_to_DB() - exiting due to too many errors
[2020-01-12 04:17:41.536 19922] MAXDBDAYS: max age for stored queries is 365 days
[2020-01-12 04:17:41.536 19922] RESOLVE_IPV6: Resolve IPv6 addresses
[2020-01-12 04:17:41.536 19922] RESOLVE_IPV4: Resolve IPv4 addresses
[2020-01-12 04:17:41.536 19922] DBINTERVAL: saving to DB file every minute
[2020-01-12 04:17:41.536 19922] DBFILE: Using /etc/pihole/pihole-FTL.db
[2020-01-12 04:17:41.536 19922] MAXLOGAGE: Importing up to 24.0 hours of log data
[2020-01-12 04:17:41.536 19922] PRIVACYLEVEL: Set to 0
[2020-01-12 04:17:41.536 19922] IGNORE_LOCALHOST: Show queries from localhost
[2020-01-12 04:17:41.536 19922] BLOCKINGMODE: Null IPs for blocked domains
[2020-01-12 04:17:41.536 19922] ANALYZE_ONLY_A_AND_AAAA: Disabled. Analyzing all queries
[2020-01-12 04:17:41.537 19922] DBIMPORT: Importing history from database
[2020-01-12 04:17:41.537 19922] PIDFILE: Using /var/run/pihole-FTL.pid
[2020-01-12 04:17:41.537 19922] PORTFILE: Using /var/run/pihole-FTL.port
[2020-01-12 04:17:41.537 19922] SOCKETFILE: Using /var/run/pihole/FTL.sock
[2020-01-12 04:17:41.537 19922] WHITELISTFILE: Using /etc/pihole/whitelist.txt
[2020-01-12 04:17:41.537 19922] BLACKLISTFILE: Using /etc/pihole/black.list
[2020-01-12 04:17:41.537 19922] GRAVITYFILE: Using /etc/pihole/gravity.list
[2020-01-12 04:17:41.537 19922] REGEXLISTFILE: Using /etc/pihole/regex.list
[2020-01-12 04:17:41.537 19922] SETUPVARSFILE: Using /etc/pihole/setupVars.conf
[2020-01-12 04:17:41.537 19922] AUDITLISTFILE: Using /etc/pihole/auditlog.list
[2020-01-12 04:17:41.537 19922] MACVENDORDB: Using /etc/pihole/macvendor.db
[2020-01-12 04:17:41.537 19922] PARSE_ARP_CACHE: Active
[2020-01-12 04:17:41.537 19922] Finished config file parsing
[2020-01-12 04:17:41.539 19922] Database version is 3
[2020-01-12 04:17:41.539 19922] Database successfully initialized
[2020-01-12 04:17:41.539 19922] Imported 0 queries from the long-term database
[2020-01-12 04:17:41.540 19922] -> Total DNS queries: 0
[2020-01-12 04:17:41.540 19922] -> Cached DNS queries: 0
[2020-01-12 04:17:41.540 19922] -> Forwarded DNS queries: 0
[2020-01-12 04:17:41.540 19922] -> Exactly blocked DNS queries: 0
[2020-01-12 04:17:41.540 19922] -> Unknown DNS queries: 0
[2020-01-12 04:17:41.540 19922] -> Unique domains: 0
[2020-01-12 04:17:41.540 19922] -> Unique clients: 0
[2020-01-12 04:17:41.540 19922] -> Known forward destinations: 0
[2020-01-12 04:17:41.540 19922] Successfully accessed setupVars.conf
*** [ DIAGNOSING ]: contents of /dev/shm
-rw------- 1 pihole pihole 323584 janv. 12 04:17 /dev/shm/FTL-clients
-rw------- 1 pihole pihole 108 janv. 12 04:17 /dev/shm/FTL-counters
-rw------- 1 pihole pihole 65536 janv. 12 04:17 /dev/shm/FTL-domains
-rw------- 1 pihole pihole 12288 janv. 12 04:17 /dev/shm/FTL-forwarded
-rw------- 1 pihole pihole 28 janv. 12 04:17 /dev/shm/FTL-lock
-rw------- 1 pihole pihole 53248 janv. 12 04:17 /dev/shm/FTL-overTime
-rw------- 1 pihole pihole 196608 janv. 12 04:17 /dev/shm/FTL-queries
-rw------- 1 pihole pihole 12 janv. 12 04:17 /dev/shm/FTL-settings
-rw------- 1 pihole pihole 4096 janv. 12 04:17 /dev/shm/FTL-strings
*** [ DIAGNOSING ]: Locale
LANG=fr_FR.UTF-8
-rw-r--r-- 1 pihole pihole 54195 janv. 12 04:17 /var/log/pihole.log
-----head of pihole.log------
Jan 12 02:17:24 dnsmasq[2312]: query[A] play.googleapis.com from 192.168.0.47
Jan 12 02:17:24 dnsmasq[2312]: forwarded play.googleapis.com to 208.67.220.220
Jan 12 02:17:24 dnsmasq[2312]: reply play.googleapis.com is 216.58.198.202
Jan 12 02:17:24 dnsmasq[2312]: reply play.googleapis.com is 216.58.204.138
Jan 12 02:18:00 dnsmasq[2312]: query[PTR] 47.0.168.192.in-addr.arpa from 127.0.0.1
Jan 12 02:18:00 dnsmasq[2312]: config 192.168.0.47 is NXDOMAIN
Jan 12 02:21:15 dnsmasq[2312]: query[A] www.google.com from 192.168.0.47
Jan 12 02:21:15 dnsmasq[2312]: forwarded www.google.com to 208.67.220.220
Jan 12 02:21:15 dnsmasq[2312]: forwarded www.google.com to 208.67.222.222
Jan 12 02:21:15 dnsmasq[2312]: reply www.google.com is 216.58.209.228
Jan 12 02:21:15 dnsmasq[2312]: reply www.google.com is 172.217.19.228
Jan 12 02:26:45 dnsmasq[2312]: query[A] connectivitycheck.gstatic.com from 192.168.0.47
Jan 12 02:26:45 dnsmasq[2312]: forwarded connectivitycheck.gstatic.com to 208.67.220.220
Jan 12 02:26:45 dnsmasq[2312]: reply connectivitycheck.gstatic.com is 216.58.213.163
Jan 12 02:26:45 dnsmasq[2312]: cached connectivitycheck.gstatic.com is 216.58.213.163
Someone can help me ?
