Hello
I've managed to get pihole DNS and DHCP running on a host docker container on a Raspberry PI 3B OK, but I'm having problem running it on a seperate virtual network interface.
Below is the script I've been editing and creating which runs fine, I'm running the pihole GUI fine on 10.0.1.0.
On the pi eth0 physical interface itself (on network interface 192.168.1.4) I can ping 10.0.1.0 and my internet router (192.168.1.254).
If I run the bash shell on the container: docker exec -it pihole /bin/bash, I can ping 192.168.1.4 (eth0) however I cannot ping 192.168.1.254 (my internet router)
Renewing windows client ipconfig/renew tells me it cannot contact the PIHole DHCP server although it appears to allocate a DHCP lease!
Rebooting doesn't help. Firewall is disabled.
No internet anywhere...
Here is ifconfig on eth0:
ifconfig
br-2b9c3826997b: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 10.0.1.254 netmask 255.255.0.0 broadcast 10.0.255.255
inet6 XXXX prefixlen 64 scopeid 0x20<link>
ether XXXX txqueuelen 0 (Ethernet)
RX packets 2313 bytes 1789062 (1.7 MiB)
TX packets 1947 bytes 398959 (389.6 KiB)
eth0: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 192.168.1.4 netmask 255.255.255.0 broadcast 192.168.1.255
inet6 XXXX prefixlen 64 scopeid 0x0<global>
ether XXXX txqueuelen 1000 (Ethernet)
RX packets 12431 bytes 1185245 (1.1 MiB)
RX errors 0 dropped 4 overruns 0 frame 0
TX packets 11109 bytes 5259139 (5.0 MiB)
lo: flags=73<UP,LOOPBACK,RUNNING> mtu 65536
inet 127.0.0.1 netmask 255.0.0.0
inet6 ::1 prefixlen 128 scopeid 0x10<host>
loop txqueuelen 1000 (Local Loopback)
RX packets 1188 bytes 929542 (907.7 KiB)
TX packets 1188 bytes 929542 (907.7 KiB)
tun0: flags=4305<UP,POINTOPOINT,RUNNING,NOARP,MULTICAST> mtu 1500
inet 10.8.0.1 netmask 255.255.255.0 destination 10.8.0.1
unspec 00-00-00-00-00-00-00-00-00-00-00-00-00-00-00-00 txqueuelen 100 (UNSPEC)
RX packets 0 bytes 0 (0.0 B)
TX packets 24 bytes 2960 (2.8 KiB)
veth8a0392a: flags=4163<UP,BROADCAST,RUNNING,MULTICAST> mtu 1500
inet 169.254.117.179 netmask 255.255.0.0 broadcast 169.254.255.255
RX packets 2313 bytes 1821444 (1.7 MiB)
TX packets 2029 bytes 412619 (402.9 KiB)
In regards to debug token (docker container exec pihole pihole -d -a) that script runs fine but I cannot upload it as there is no internet until I reconfigure it to run on host network (whereupon the debug log will have changed).
Is there a manual process for this? The instructions URL given by the debug doesn't give me any light in the matter...
https://pi-hole.net/2016/11/07/crack-our-medical-tricorder-win-a-raspberry-pi-3/ doesn't tell me anything..
Finally my script is below....
Thanks for any help....
docker container stop pihole
docker container rm pihole
docker network rm br0
docker network create \
--driver=bridge \
--subnet=10.0.0.0/16 \
--ip-range=10.0.1.0/24 \
--gateway=10.0.1.254 \
br0
PIHOLE_BASE="${PIHOLE_BASE:-$(pwd)}"
[[ -d "$PIHOLE_BASE" ]] || mkdir -p "$PIHOLE_BASE" || { echo "Couldn't create storage directory: $PIHOLE_BASE"; exit 1; }
# Note: ServerIP should be replaced with your external ip.
docker run -d \
--name pihole \
-p 53:53/tcp -p 53:53/udp \
-p 80:80 \
-p 443:443/tcp \
-p 67:67/udp \
--cap-add=NET_ADMIN \
-e TZ="Europe/London" \
-v "${PIHOLE_BASE}/etc-pihole/:/etc/pihole/" \
-v "${PIHOLE_BASE}/etc-dnsmasq.d/:/etc/dnsmasq.d/" \
--dns=127.0.0.1 --dns=1.1.1.1 \
--restart=unless-stopped \
--hostname pi.hole \
-e VIRTUAL_HOST="pi.hole" \
-e PROXY_LOCATION="pi.hole" \
-e ServerIP="10.0.1.0" \
--network br0 \
pihole/pihole:latest
printf 'Starting up pihole container '
for i in $(seq 1 20); do
if [ "$(docker inspect -f "{{.State.Health.Status}}" pihole)" == "healthy" ] ; then
printf ' OK'
echo -e "\n$(docker logs pihole 2> /dev/null | grep 'password:') for your pi-hole: https://${IP}/admin/"
exit 0
else
sleep 3
printf '.'
fi
if [ $i -eq 20 ] ; then
echo -e "\nTimed out waiting for Pi-hole start, consult your container logs for more info (\`docker logs pihole\`)"
exit 1
fi
done;
... so I have to go back running pihole on a container running on host for the meantime which works for now, but I really would like vlan working.
