This log if from the other day. I can generate one from today if you'd like, just let me know.
Also, the 65.4.154.xx base IP is my custom IP for my network. That's manually configured by me. Changed from the normal 192.168.1.xx
Detecting Installed Package Versions:
Pi-hole: v2.11.2
WebUI: v2.3.1
lighttpd/1.4.35
PHP 5.6.29-0+deb8u1 (cli) (built: Dec 17 2016 06:04:43)
Detecting existence of /etc/pihole/setupVars.conf:
PIHOLE_INTERFACE=eth0
IPV4_ADDRESS=65.4.154.51
IPV6_ADDRESS=
PIHOLE_DNS_1=8.8.8.8
PIHOLE_DNS_2=8.8.4.4
QUERY_LOGGING=true
WEBPASSWORD=
Detecting installed OS Distribution
PRETTY_NAME="Raspbian GNU/Linux 8 (jessie)"
NAME="Raspbian GNU/Linux"
VERSION_ID="8"
VERSION="8 (jessie)"
ID=raspbian
ID_LIKE=debian
HOME_URL="http://www.raspbian.org/"
SUPPORT_URL="http://www.raspbian.org/RaspbianForums"
BUG_REPORT_URL="http://www.raspbian.org/RaspbianBugs"
Checking processor variety
armv6l
IP Address Information
::1/128
fe80::272b:70b3:a8f5:94f8/64
127.0.0.1/8
65.4.154.51/8
--- 65.4.154.41 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2001ms
rtt min/avg/max/mdev = 0.441/0.484/0.545/0.050 ms
--- 8.8.8.8 ping statistics ---
3 packets transmitted, 3 received, 0% packet loss, time 2003ms
rtt min/avg/max/mdev = 14.113/16.467/18.811/1.917 ms
Daemon Process Information
Found user root with process apache2
Failure: IPv4 Port not in use
Found user dnsmasq with process dnsmasq
Processes Check
lighttpd
processes status:
â— lighttpd.service - Lighttpd Daemon
Loaded: loaded (/lib/systemd/system/lighttpd.service; enabled)
Active: failed (Result: exit-code) since Tue 2017-01-17 08:14:04 UTC; 11h ago
Process: 674 ExecStart=/usr/sbin/lighttpd -D -f /etc/lighttpd/lighttpd.conf (code=exited, status=255)
Process: 616 ExecStartPre=/usr/sbin/lighttpd -t -f /etc/lighttpd/lighttpd.conf (code=exited, status=0/SUCCESS)
Main PID: 674 (code=exited, status=255)
Jan 17 08:14:01 raspberrypi lighttpd[616]: Syntax OK
Jan 17 08:14:01 raspberrypi systemd[1]: Started Lighttpd Daemon.
Jan 17 08:14:04 raspberrypi lighttpd[674]: 2017-01-17 08:14:01: (network.c.409) can't bind to port: 80 Address already in use
Jan 17 08:14:04 raspberrypi systemd[1]: lighttpd.service: main process exited, code=exited, status=255/n/a
Jan 17 08:14:04 raspberrypi systemd[1]: Unit lighttpd.service entered failed state.
dnsmasq
processes status:
â— dnsmasq.service - dnsmasq - A lightweight DHCP and caching DNS server
Loaded: loaded (/lib/systemd/system/dnsmasq.service; enabled)
Drop-In: /run/systemd/generator/dnsmasq.service.d
└─50-dnsmasq-$named.conf, 50-insserv.conf-$named.conf
Active: active (running) since Tue 2017-01-17 08:13:53 UTC; 11h ago
Main PID: 413 (dnsmasq)
CGroup: /system.slice/dnsmasq.service
└─413 /usr/sbin/dnsmasq -x /var/run/dnsmasq/dnsmasq.pid -u dnsmasq -r /var/run/dnsmasq/resolv.conf -7 /etc/dnsmasq.d,.dpkg-dist,.dpkg-old,.dpkg-new --local-service
Jan 17 08:13:50 raspberrypi systemd[1]: Starting dnsmasq - A lightweight DHCP and caching DNS server...
Jan 17 08:13:50 raspberrypi dnsmasq[363]: dnsmasq: syntax check OK.
Jan 17 08:13:53 raspberrypi systemd[1]: Started dnsmasq - A lightweight DHCP and caching DNS server.
Resolver Functions Check
Resolution of doubleclick.com from Pi-hole:
; <<>> DiG 9.9.5-9+deb8u9-Raspbian <<>> doubleclick.com @127.0.0.1
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 37944
;doubleclick.com. IN A
doubleclick.com. 300 IN A 65.4.154.51
;; Query time: 5 msec
;; WHEN: Tue Jan 17 19:59:08 UTC 2017
;; MSG SIZE rcvd: 60
Resolution of doubleclick.com from 8.8.8.8:
; <<>> DiG 9.9.5-9+deb8u9-Raspbian <<>> doubleclick.com @8.8.8.8
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 62688
doubleclick.com. 299 IN A 172.217.3.206
;; Query time: 23 msec
;; SERVER: 8.8.8.8#53(8.8.8.8)
Pi-hole dnsmasq specific records lookups
Cache Size:
"10000"
Upstream Servers:
"8.8.4.4#53 14 0" "8.8.8.8#53 16 2"
Detecting existence of /etc/lighttpd/lighttpd.conf:
server.modules = (
"mod_access",
"mod_accesslog",
"mod_auth",
"mod_expire",
"mod_compress",
"mod_redirect",
"mod_setenv",
"mod_rewrite"
server.error-handler-404 = "pihole/index.php"
server.pid-file = "/var/run/lighttpd.pid"
server.username = "www-data"
server.groupname = "www-data"
server.port = 80
url.access-deny = ( "~", ".inc" )
compress.filetype = ( "application/javascript", "text/css", "text/html", "text/plain" )
include_shell "/usr/share/lighttpd/create-mime.assign.pl"
include_shell "/usr/share/lighttpd/include-conf-enabled.pl"
$HTTP["url"] =~ "^/admin/" {
"X-Frame-Options" => "DENY"
url.rewrite = ( "^(?!/admin/).*\.js$" => "pihole/index.js" )
$HTTP["url"] =~ "^(?!/admin)/.*" {
setenv.add-response-header = ( "X-Pi-hole" => "A black hole for Internet advertisements." )
Detecting existence of /var/log/lighttpd/error.log:
2017-01-17 07:29:28: (log.c.164) server started
2017-01-17 07:31:24: (server.c.1558) server stopped by UID = 0 PID = 1
2017-01-17 07:31:27: (log.c.164) server started
2017-01-17 08:13:36: (server.c.1558) server stopped by UID = 0 PID = 1
Detecting existence of /etc/dnsmasq.conf:
conf-dir=/etc/dnsmasq.d
Detecting existence of /etc/dnsmasq.d/01-pihole.conf:
domain-needed
bogus-priv
no-resolv
server=8.8.8.8
server=8.8.4.4
interface=eth0
cache-size=10000
log-queries
local-ttl=300
log-async
Detecting existence of /etc/pihole/whitelist.txt:
raw.githubusercontent.com
mirror1.malwaredomains.com
sysctl.org
zeustracker.abuse.ch
s3.amazonaws.com
hosts-file.net
Detecting existence of /etc/pihole/blacklist.txt:
/etc/pihole/blacklist.txt not found!
Detecting existence of /etc/pihole/adlists.list:
/etc/pihole/adlists.list not found!
Analyzing gravity.list
/etc/pihole/gravity.list is 95120 /etc/pihole/gravity.list lines long.
pihole.log
