hi. what are the best blacklist 2021 thanks.. i ve started from this page.. using green ones
The best blocklist will vary based on the devices and traffic within your network. You found a great starting point! From there I recommend using Yubiuser's Pihole Adlist Tool to check your blocklists against your own traffic.
wget https://raw.githubusercontent.com/yubiuser/pihole_adlist_tool/master/pihole_adlist_tool
mv pihole_adlist_tool pihole_adlist_tool.sh
chmod +x pihole_adlist_tool.sh
Help:
./pihole_adlist_tool.sh -h
Compare entire database instead of past 30 days:
./pihole_adlist_tool.sh -d 0
- Enable all adlists (runs pihole -g)
- Enable the minimal number of adlists that cover all domains that would have been blocked
Hope this helps.
thanks very interessant. but i havn t understand
- Keep your current adlist configuration
- Enable only adlists with covered unique domains
which one is better for my pi1 and have no stress the ram?
thanks
