The status of Web Admin should be active all the time and the ENABLE button from the left navigation panel should not be there as the pihole has to be enabled by default
(a little background of my setup, I'm trying to install in my old Galaxy S5, OS is Ubuntu and I've set up a static IP for it)
When I click Enable it stays enabled until I just click on some other links from the same menu and the status goes back to unknown from active
Your debug log is very unusual. It appears that Pi-hole is working, but many of the processes are not reporting properly.
Examples:
[✗] lighttpd daemon is
[✗] pihole-FTL daemon is
*** [ DIAGNOSING ]: Pi-hole-FTL full status
(this section is blank, but should be reporting the serice status for pihole-FTL)
Timeout: 10 seconds
WARN: Could not sendto() in send_dhcp_discover() (/root/project/src/dhcp-discover.c:228): Network is unreachable
DHCP packets received on interface rmnet_usb0: 0
DHCP packets received on interface rev_rmnet0: 0
DHCP packets received on interface rev_rmnet5: 0
DHCP packets received on interface sit0: 0
DHCP packets received on interface rev_rmnet7: 0
DHCP packets received on interface rev_rmnet3: 0
DHCP packets received on interface rev_rmnet6: 0
DHCP packets received on interface rev_rmnet8: 0
DHCP packets received on interface dummy0: 0
DHCP packets received on interface rev_rmnet2: 0
DHCP packets received on interface rev_rmnet1: 0
DHCP packets received on interface p2p0: 0
DHCP packets received on interface wlan0: 0
DHCP packets received on interface rev_rmnet4: 0
