I updated to pihole 6 and noticed, that if I open https://127.0.0.1:8443
instead of https://127.0.0.1:8443/admin
it shows the code from my index.php on my regular webserver.
This was kinda expected so I moved the pihole-web to /usr/share/pihole/pihole
and defined webroot as /usr/share/pihole
and subpath as /pihole/
This worked, but now I read here that I can't use this setting, because everything is hardcoded in pihole.
Why is this option there than?
What is the offical workaround, so not everthing is exposed?
Of cause I'm using a reverse proxy, but it's still exposed in my local network.
Do I really have to work with iptables?
In my opinion this shouldn't be the case.
edit:
I kinda solved it with:
acl = "+127.0.0.1,+[::1]"
port = "127.0.0.1:8443s"
I'm still not a fan of the design choise.
The path for the webfiles really shouldn't be in /var/www/ if you are using your own webserver.
At least there has to be something in the webserver which blocks everything which isn't in the defined subpath.
