Remote Switch Chrome plugin for Pi-Hole was working fine showing status and allowing to easily enable/disable PiHole.
Just upgraded PiHole to 5.0 and it stopped to work, tried other switches and they also does not run. Checked, the API key is not changed, I have a correct API key entered.
API access has to be enabled first somehow now?
will do, but there is another similar plugin in chrome web store Pi-Hole On/Off extension and it does not work exactly the same way with PiHole 5 as well.
