Hi there,
I'm using Raspberry Pi 4b with ubuntu its 20.4 and ipv6. PiHole is configured as DHCP server. If I reboot everything it's working fine. However my pi doesn't update it's external ipv6 after it's deprecated. How can I make it to automatically renew it's ipv6?
*If you are Experiencing issues with a Pi-hole install that has non-standard
Standard Configuration ipv6 enabled
The Pi running ubuntu 20.4 its with PiHole should automatically realize when it's ipv6 address becomes depreciated. It should than get a new one or renew the old one.
If I reboot the pi it gets a working external ipv6. However it will not update this ipv6 when it becomes deprecated or even when it can't be used any longer.
Output of "ip -6 address show" is:
eth0: <BROADCAST,MULTICAST,UP,LOWER_UP> mtu 1500 state UP qlen 1000
inet6 2a02:3033:414:e659:e65f:1ff:fe71:aa06/64 scope global deprecated dynamic mngtmpaddr noprefixroute
valid_lft 3582sec preferred_lft 0sec
Rebooting the pi will fix this issue but only for 1h. Because afterwards it deprecated again.
