hi anyone
i use this commad:
for run pi-hole:
sudo docker run --net piholeNetwork --ip 172.16.0.22 --name piho
le -p 53:53/udp -p 53:53/tcp -p 67:67/udp -p 80:80/tcp -p 443:443/tcp -e TZ=Asia/Tehr
an -v /home/mohammad/Documents/docker/pihole/etc-pihole/:/etc/pihole -v /home/mohamma
d/Documents/docker/pihole/et-dnsmasq.d/:/etc/dnsmasq.d/ -e ServerIP=162.223.91.151 -e
WEBPASSWORD=km2140 --cap-add=NET_ADMIN -d pihole/pihole:latest
and now all of theme it's ok on protocol http but if i use https for websits:
example http://google.com
it's ok and block it
but if i use https://google.com
it's can't block it
please help me for solve it thank you very much
jfb
April 30, 2021, 2:32pm
2
http://google.com
or https://google.com
are URL's.
The domain for each is google.com
, and this is what Pi-hole filters.
It is unlikely that google.com
is on a blocklist, but since you have not provided a debug log, we can't see your blocking.
Tools > Generate Debug Log
thank you for read my question
and this my log:
https://paste.debian.net/1195814/
jfb
May 1, 2021, 10:44am
4
You have both google.com and www.google.com on your blacklist. You also have a number of odd regex entries in there as well, like port numbers, etc.
id type enabled group_ids domain date_added date_modified comment
1 3 1 0 location.services.mozilla.com 2020-02-03 17:58:55 2021-04-30 12:03:48
2 1 1 0 phoscon.de 2020-02-03 17:58:55 2021-04-30 07:45:23
4 1 1 0 dresden-light.appspot.com 2020-02-03 17:58:55 2021-04-30 07:45:23
5 1 1 0 api.update.ledvance.com 2020-02-03 17:58:55 2021-04-30 07:45:23
7 1 1 0 netdata.cloud 2020-02-03 17:58:55 2021-04-30 07:45:23
10 3 1 0 (^|\.)dresden-elektronik\.de$ 2020-02-03 17:58:55 2021-04-30 07:45:23
11 3 1 0 (^|\.)nintendo\.com$ 2020-02-03 17:58:55 2021-04-30 07:45:23
12 3 1 0 (^|\.)phoscon\.de$ 2020-02-03 17:58:55 2021-04-30 07:45:23
13 3 1 0 (^|\.)my-netdata\.io$ 2020-02-03 17:58:55 2021-04-30 07:45:23
14 3 1 0 (^|\.)netdata\.cloud$ 2020-02-03 17:58:55 2021-04-30 07:45:23
15 3 1 0 (^|\.)ledvance\.com$ 2020-02-03 17:58:55 2021-04-30 07:45:23
17 3 1 0 (\.|^)uriports\.com$ 2020-02-04 09:29:31 2021-04-30 07:45:23
18 1 1 0 stats.lineageos.org 2020-02-04 13:39:18 2021-04-30 07:45:23
19 1 1 0 grafana.com 2020-02-09 12:36:46 2021-04-30 07:45:23
22 1 1 0 telemetry.caddyserver.com 2020-02-25 22:37:33 2021-04-30 07:45:23
23 1 1 0 piwik.netrange.com 2020-02-25 22:46:55 2021-04-30 07:45:23
25 1 1 0 matomo.netrange.com 2020-02-25 22:48:47 2021-04-30 07:45:23
26 3 1 0 (\.|^)google\.ru$ 2020-02-26 10:55:40 2021-04-30 07:45:23
31 1 1 0 safebrowsing.googleapis.com 2020-03-08 21:49:07 2021-04-30 07:45:23
67 3 1 0 (\.|^)s\.w\.org$ 2020-05-14 16:11:11 2021-04-30 07:45:23
68 1 1 0 stun.us.demonware.net 2020-05-30 10:28:17 2021-04-30 07:45:23
69 1 1 0 app-b02.lp1.npns.srv.nintendo.net 2020-05-30 10:29:34 2021-04-30 07:45:23
70 3 1 0 (\.|^)nintendo\.net$ 2020-05-30 10:29:55 2021-04-30 07:45:23
71 3 1 0 (\.|^)sudo$ 2021-04-30 11:56:25 2021-04-30 11:56:25
72 3 1 0 (\.|^)docker$ 2021-04-30 11:56:25 2021-04-30 11:56:25
73 3 1 0 (\.|^)run$ 2021-04-30 11:56:25 2021-04-30 11:56:25
74 3 1 0 (\.|^)--net$ 2021-04-30 11:56:25 2021-04-30 11:56:25
75 3 1 0 (\.|^)piholenetwork$ 2021-04-30 11:56:25 2021-04-30 11:56:25
76 3 1 0 (\.|^)--ip$ 2021-04-30 11:56:25 2021-04-30 11:56:25
77 3 1 0 (\.|^)172\.16\.0\.22$ 2021-04-30 11:56:25 2021-04-30 11:56:25
78 3 1 0 (\.|^)--name$ 2021-04-30 11:56:25 2021-04-30 11:56:25
79 3 1 0 (\.|^)pihole$ 2021-04-30 11:56:25 2021-04-30 11:56:25
80 3 1 0 (\.|^)-p$ 2021-04-30 11:56:25 2021-04-30 11:56:25
81 3 1 0 (\.|^)53:53/udp$ 2021-04-30 11:56:25 2021-04-30 11:56:25
83 3 1 0 (\.|^)53:53/tcp$ 2021-04-30 11:56:25 2021-04-30 11:56:25
85 3 1 0 (\.|^)67:67/udp$ 2021-04-30 11:56:25 2021-04-30 11:56:25
87 3 1 0 (\.|^)80:80/tcp$ 2021-04-30 11:56:25 2021-04-30 11:56:25
88 3 1 0 (\.|^)-e$ 2021-04-30 11:56:25 2021-04-30 11:56:25
89 3 1 0 (\.|^)tz=asia/$ 2021-04-30 11:56:25 2021-04-30 11:56:25
90 3 1 0 (\.|^)-v$ 2021-04-30 11:56:25 2021-04-30 11:56:25
91 3 1 0 (\.|^)/home/home/documents/docker/pihole/etc-pihole/:/etc/pihole$ 2021-04-30 11:56:25 2021-04-30 11:56:25
93 3 1 0 (\.|^)/home/home/documents/docker/pihole/et-dnsmasq\.d/:/etc/dnsmasq\.d/$ 2021-04-30 11:56:25 2021-04-30 11:56:25
95 3 1 0 (\.|^)serverip=162\.223\.91\.151$ 2021-04-30 11:56:25 2021-04-30 11:56:25
97 3 1 0 (\.|^)webpassword=km2140$ 2021-04-30 11:56:25 2021-04-30 11:56:25
98 3 1 0 (\.|^)--cap-add=NET_ADMIN$ 2021-04-30 11:56:25 2021-04-30 11:56:25
99 3 1 0 (\.|^)-d$ 2021-04-30 11:56:25 2021-04-30 11:56:25
100 3 1 0 (\.|^)pihole/pihole:latest$ 2021-04-30 11:56:25 2021-04-30 11:56:25
112 1 1 0 pi-hole.net 2021-04-30 13:25:21 2021-04-30 13:25:21
113 1 1 0 www.google.com 2021-04-30 14:36:42 2021-04-30 14:36:42
114 1 1 0 google.com 2021-04-30 14:37:17 2021-04-30 14:39:45
