I'm running pi-hole inside Hassio in a Docker container on my Synology NAS GitHub - hassio-addons/addon-pi-hole: Pi-hole - Home Assistant Community Add-ons and changed the Primary DNS settings on my Amplifi HD router to the Synology's IP address and the Secondary DNS blank.
My setup is Internet <-> Virgin Superhub3 (modem mode) <-> Amplifi <-> Synology (all ethernet).
I installed pi-hole and can log into the web UI but it says that the DNS service is not running and the FTL service is offline.
The config file is:
"update_lists_on_start": true,
"ssl": true,
"certfile": "fullchain.pem",
"keyfile": "privkey.pem",
"interface": "",
"ipv6": true,
"ipv4_address": "",
"ipv6_address": "",
"virtual_host": "pi-hole",
"hosts": []
I'm a bit of a noob and would appreciate any pointers.
Thanks
