Hello to all of you
I want to run Pi-Hole on my Ds415 + but I can not configure it properly. The container reboots systematically.
I need help !!
Here are the error messages:
ERROR: To function correctly you must pass an environment variables of ‘ServerIP’ into the docker container with the IP of your docker host from which you are passing web (80) and dns (53) ports from
In the environment variables I put ServerIP 192.168.1.250
WARNING Misconfigured DNS in /etc/resolv.conf: Primary DNS should be 127.0.0.1 (found nameserver 192.168.1.1
Should I edit the resolv.conf file? How to do ?
Thanks for your help
