Pi-hole container fails to start
It restarts in a loop every couple seconds. Had to manually create the folders and files on the host because they created as directories originally??
**$** docker logs -f pihole
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] 01-resolver-resolv: applying...
[fix-attrs.d] 01-resolver-resolv: exited 0.
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] 20-start.sh: executing...
stty: 'standard input': Inappropriate ioctl for device
::: Starting docker specific checks & setup for docker pihole/pihole
[cont-init.d] 20-start.sh: exited 1.
[cont-finish.d] executing container finish scripts...
[cont-finish.d] done.
[s6-finish] syncing disks.
[s6-finish] sending all processes the TERM signal.
[s6-finish] sending all processes the KILL signal and exiting.
[fix-attrs.d] done.
[fix-attrs.d] done.
Service doesn't start so I cannot run this command.
Linux raspberrypi 4.14.98-v7+ #1200 SMP Tue Feb 12 20:27:48 GMT 2019 armv7l GNU/Linux
Docker version 18.06.3-ce, build d7080c1
docker-compose.yml
version: '2'
services:
pihole:
container_name: pihole
image: pihole/pihole:4.3.1-4_armhf
hostname: pi-hole
mac_address: d0:ca:ab:cd:ef:01
cap_add:
- NET_ADMIN
ports:
- 443/tcp
#- 53/tcp
#- 53/udp
# - 67/udp # Uncomment if you want to use Pi-Hole for DHCP
- 80/tcp
#- 22/tcp
environment:
ServerIP: 192.168.1.222
WEBPASSWORD: ${WEBPASSWORD}
DNS1: 192.168.1.202
DNS2: 192.168.1.202
PH_VERSION: 1
volumes:
- /home/pi/docker/docker-pihole-unbound/volume:/etc/pihole:rw
- /home/pi/docker/docker-pihole-unbound/pihole/config/hosts:/etc/hosts:rw
- /home/pi/docker/docker-pihole-unbound/pihole/config/resolv.conf:/etc/resolv.conf:rw
- /home/pi/docker/docker-pihole-unbound/pihole/config/dnsmasq.conf:/etc/dnsmasq.d/02-network.conf:rw
- /home/pi/docker/docker-pihole-unbound/pihole/config/pihole-FTL.conf:/etc/pihole/pihole-FTL.conf:rw
networks:
home:
ipv4_address: 192.168.1.222
restart: always
unbound:
container_name: unbound
image: mvance/unbound:rpi
hostname: syn-unbound
mac_address: d0:ca:ab:cd:ef:02
ports:
- 53/tcp
- 53/udp
networks:
home:
ipv4_address: 192.168.1.202
restart: always
networks:
home:
driver: macvlan
driver_opts:
parent: eth0
ipam:
config:
- subnet: 192.168.1.0/24
gateway: 192.168.1.1
ip_range: 192.168.1.0/24 # 192.168.1.5 and 192.168.1.6
unbound seems to start without issue.
diginc
July 31, 2019, 1:40am
3
add environment of PH_VERBOSE: 1
and down + up to get more meaningful logs.
edit: sorry I meant PH_VERBOSE
not PH_DEBUG
[fix-attrs.d] done.
+ bashCmd='bash -e -x'
+ bash -e -x /start.sh
+ export TAG
+ export ServerIP
+ export ServerIPv6
+ export PYTEST
+ export PHP_ENV_CONFIG
+ export PHP_ERROR_LOG
+ export HOSTNAME
+ export WEBLOGDIR
+ export DNS1
+ export DNS2
+ export INTERFACE
+ export DNSMASQ_LISTENING_BEHAVIOUR=
+ DNSMASQ_LISTENING_BEHAVIOUR=
+ export IPv6
+ export WEB_PORT
+ export adlistFile=/etc/pihole/adlists.list
+ adlistFile=/etc/pihole/adlists.list
+ . /bash_functions.sh
++ . /opt/pihole/webpage.sh
+++ setupVars=/etc/pihole/setupVars.conf
+++ dnsmasqconfig=/etc/dnsmasq.d/01-pihole.conf
+++ dhcpconfig=/etc/dnsmasq.d/02-pihole-dhcp.conf
+++ FTLconf=/etc/pihole/pihole-FTL.conf
+++ dhcpstaticconfig=/etc/dnsmasq.d/04-pihole-static-dhcp.conf
+++ coltable=/opt/pihole/COL_TABLE
+++ [[ -f /opt/pihole/COL_TABLE ]]
+++ source /opt/pihole/COL_TABLE
++++ [[ -t 1 ]]
++++ COL_BOLD=
++++ COL_ULINE=
++++ COL_NC=
++++ COL_GRAY=
++++ COL_RED=
++++ COL_GREEN=
++++ COL_YELLOW=
++++ COL_BLUE=
++++ COL_PURPLE=
++++ COL_CYAN=
++++ COL_WHITE=
++++ COL_BLACK=
++++ COL_LIGHT_BLUE=
++++ COL_LIGHT_GREEN=
++++ COL_LIGHT_CYAN=
++++ COL_LIGHT_RED=
++++ COL_URG_RED=
++++ COL_LIGHT_PURPLE=
++++ COL_BROWN=
++++ COL_LIGHT_GRAY=
++++ COL_DARK_GRAY=
++++ TICK='[✓]'
++++ CROSS='[✗]'
++++ INFO='[i]'
++++ QST='[?]'
++++ DONE=' done!'
++++ OVER='\r'
+ PH_TEST=true
+ . /root/ph_install.sh
++ set -e
+++ cat
++ DNS_SERVERS='Google (ECS);8.8.8.8;8.8.4.4;2001:4860:4860:0:0:0:0:8888;2001:4860:4860:0:0:0:0:8844
OpenDNS (ECS);208.67.222.222;208.67.220.220;2620:0:ccc::2;2620:0:ccd::2
Level3;4.2.2.1;4.2.2.2;;
Comodo;8.26.56.26;8.20.247.20;;
DNS.WATCH;84.200.69.80;84.200.70.40;2001:1608:10:25:0:0:1c04:b12f;2001:1608:10:25:0:0:9249:d69b
Quad9 (filtered, DNSSEC);9.9.9.9;149.112.112.112;2620:fe::fe;2620:fe::9
Quad9 (unfiltered, no DNSSEC);9.9.9.10;149.112.112.10;2620:fe::10;2620:fe::fe:10
Quad9 (filtered + ECS);9.9.9.11;149.112.112.11;2620:fe::11;
Cloudflare;1.1.1.1;1.0.0.1;2606:4700:4700::1111;2606:4700:4700::1001'
++ installLogLoc=/etc/pihole/install.log
++ lighttpdConfig=/etc/lighttpd/lighttpd.conf
++ webroot=/var/www/html
++ webInterfaceGitUrl=https://github.com/pi-hole/AdminLTE.git
++ webInterfaceDir=/var/www/html/admin
++ piholeGitUrl=https://github.com/pi-hole/pi-hole.git
++ PI_HOLE_LOCAL_REPO=/etc/.pihole
++ PI_HOLE_FILES=(chronometer list piholeDebug piholeLogFlush setupLCD update version gravity uninstall webpage)
++ PI_HOLE_INSTALL_DIR=/opt/pihole
++ PI_HOLE_CONFIG_DIR=/etc/pihole
++ PI_HOLE_BLOCKPAGE_DIR=/var/www/html/pihole
++ useUpdateVars=false
++ adlistFile=/etc/pihole/adlists.list
++ regexFile=/etc/pihole/regex.list
++ IPV4_ADDRESS=
++ IPV6_ADDRESS=
++ QUERY_LOGGING=true
++ INSTALL_WEB_INTERFACE=true
++ PRIVACY_LEVEL=0
++ '[' -z '' ']'
+++ id -un
++ USER=root
+++ stty size
+++ printf '%d %d' 24 80
++ screen_size='24 80'
++ printf -v rows %d 24
++ printf -v columns %d 80
++ r=12
++ c=40
++ r=20
++ c=70
++ skipSpaceCheck=false
++ reconfigure=false
++ runUnattended=false
++ INSTALL_WEB_SERVER=true
+++ [[ -t 1 ]]
+++ COL_BOLD=
+++ COL_ULINE=
+++ COL_NC=
+++ COL_GRAY=
+++ COL_RED=
+++ COL_GREEN=
+++ COL_YELLOW=
+++ COL_BLUE=
+++ COL_PURPLE=
+++ COL_CYAN=
+++ COL_WHITE=
+++ COL_BLACK=
+++ COL_LIGHT_BLUE=
+++ COL_LIGHT_CYAN=
+++ COL_LIGHT_RED=
+++ COL_URG_RED=
+++ COL_BROWN=
+++ COL_LIGHT_GRAY=
+++ COL_DARK_GRAY=
+++ TICK='[✓]'
+++ CROSS='[✗]'
+++ INFO='[i]'
+++ QST='[?]'
+++ DONE=' done!'
+++ OVER='\r'
++ binary=tbd
++ counter=0
++ [[ true != true ]]
+ echo ' ::: Starting docker specific checks & setup for docker pihole/pihole'
+ docker_checks
+ warn_msg='WARNING Misconfigured DNS in /etc/resolv.conf'
++ grep -c nameserver /etc/resolv.conf
+ ns_count=0
diginc
August 3, 2019, 10:40pm
5
+ ns_count=0
That is strange it crashes on the nameserver detection section - it isn't meant to exit but just warn users that things maybe configured wrong...I'll look into that code a little closer and reply more if more comes to mind there.
Since the count of nameservers is zero perhaps that is bombing it out, you might try adding at least one to see if that helps: https://github.com/pi-hole/docker-pi-hole/blob/master/docker-compose.yml#L25-L27
system
Closed
August 24, 2019, 10:40pm
6
