The issue I am facing:
Pi-hole is recognizing client requests and accepting the internet traffic, but there is never a response back to the client. Navigating to google.com in a web browser connected to the WAP results in request timeouts, and similar behavior is found when running a traceroute
$ traceroute google.com traceroute: Warning: google.com has multiple addresses; using 173.194.219.139 traceroute to google.com (173.194.219.139), 64 hops max, 52 byte packets 1 raspberrypi (192.168.4.1) 1.900 ms 2.524 ms 3.239 ms 2 * * *
Details about my system:
I am running a Raspberry Pi 4B, 8GB RAM that I've set up as a routed wireless access point per these instructions, with the exception of not installing dnsmasq
on the Pi itself. I've installed Pi-hole in Docker with the v5.1.1 image, and have configured dnsmasq
there to act as the DHCP server for the WAP. I'm able to connect to this WAP and communicate with the Pi on that network, just not out to the internet.
- Enabled the DHCP server in the DHCP settings in Pi-hole, updated the range of IPs, and added the WAP's IP address as the gateway IP (192.168.4.1).
- Added the ServerIP environment variable to docker-comose.yaml, setting it to the WAP's IP, and modified the password and timezone variables as well. Also set up to use host networking.
pihole_debug.txt (20.8 KB)
docker-compose.txt (808 Bytes)
Thanks for the help!
