Looks like Pihole is working when accessed from your device at 192.168.0.201.
Whatever device is at 192.168.0.64 is sending requests to the Pihole as well, but I don't know what device that is. If you accessed msn.com from your iPhone during this logged period you've shown, the iPhone doesn't seem to be using Pihole for DNS for those queries.
The takeaway is that you're going to want to determine what device is using which DNS. iPhones show their configured DNS under Settings/Wifi then clicking on the Info button by the SSID you're connected to, Configure DNS. The DNS servers will be listed on "Configure DNS" details screen. If they're not what you're expecting, you can switch to Manual on this screen and enter the address of your Pihole (at least for testing).
That is exactly what I did, the 192.168.0.64 is actually the iPhone ip address, DNS was configured automatically to 192.168.0.170. When I saw that this did not solve the problem I added it manually. Even with it being available manually sometimes it does not use this DNS. That is what I think atleast because it doesn't always show under query log in Pi-hole.
One of your previous screenshots shows that you have explicitly disabled IPv6 on your Windows machine.
However, your debug log shows that your network has indeed full IPv6 connectivity:
[✓] smetrics.home.kpmg is :: on lo (::1)
[✓] smetrics.home.kpmg is on eno1 (fe80::<redacted>)
[✓] No IPv6 address available on wlp1s0b1
[✓] doubleclick.com is via a remote, public DNS server (2001:4860:4860::8888)
Together with your observation that none of your iPhone's DNS requests are registering in Pi-hole, that would strongly suggest that your iPhone would use another DNS server, most likely your router's IPv6.
You should be able to verify that by re-enabling IPv6 protocols on your Windows machine and rechecking its ipconfig DNS servers.
I did not understand properly. But do you mean if I see an IPv6 Address in the cmd command, then that would mean that my router is enabling IPv6? and I should disable IPv6 on my router?
This is the command output on CMD after enabling IPv6:
ipconfig
Windows IP Configuration
Unknown adapter SecureLine:
Media State . . . . . . . . . . . : Media disconnected
Connection-specific DNS Suffix . :
Ethernet adapter Ethernet:
Link-local IPv6 Address . . . . . : BLURRED
IPv4 Address. . . . . . . . . . . : 192.168.0.201
Default Gateway . . . . . . . . . : 192.168.0.1
Wireless LAN adapter Wi-Fi:
Wireless LAN adapter Local Area Connection* 1:
Wireless LAN adapter Local Area Connection* 2:
Ethernet adapter Bluetooth Network Connection:
If you meant I should run ipconfig /all then this is the part regarding the Ethernet adapter:
. NOTE: I honestly have no idea if I am supposed to show the IPv6 address or not, so when you see BLURRED I removed the addresses and write it manually.
The screenshot shows that I did not set a DNS address (as I do not know whether I should do it for Pi-hole or not, neither do I know how):
You can check what DNS server(s) is/are advertised via router IPv6 RA (Router Advertisement) if install below on the Pi-hole or other Linux host:
sudo apt install ndisc6
FYI:
$ apt show ndisc6
Description: IPv6 diagnostic tools
ndisc6 gathers a few diagnostic tools for IPv6 networks including:
- ndisc6, which performs ICMPv6 Neighbor Discovery in userland,
- rdisc6, which performs ICMPv6 Router Discovery in userland,
- rltraceroute6, a UDP/ICMP IPv6 implementation of traceroute,
- tcptraceroute6, a TCP/IPv6-based traceroute implementation,
- tcpspray6, a TCP/IP Discard/Echo bandwidth meter,
- addrinfo, easy script interface for hostname and address resolution,
- dnssort, DNS sorting script.
If you run below one, it will show you the MAC address from which the RA is coming from, the IPv6 prefixes and DNS server(s) advertised:
rdisc6 <NETWORK_INTERFACE_NAME>
Maybe it needs sudo in front of it or root powers for your distro.
